AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Onkyo SC5508 Surround processor [No Price Talk]
Onkyo SC5508 Surround processor [No Price Talk] - Page 78
post #2311 of 2653
Originally Posted by SoundofMind View Post
Very nice work, thnx for the report.
Thanks SoM - I forgot to add an important point which concerns the integration of the surround and main channels. I am about to edit my original report to make that point.
Good move. As you know, as XT32 does not rank crossovers, so there's no good reason not to raise them to 80 (and good reasons to raise them).
Indeed.
I'll be very interested in that report! Of course, we'll want xposts to the Pro thread.[/quote]
Natch
post #2312 of 2653
Originally Posted by pepar View Post
Thanks, Keith, for your usual thoroughness in approaching this. I think you have experienced what the conventional wisdom expected.
Don't know about the less punch thing, maybe the result of sampling 8 positions and not 12. Which positions were dropped?
Jeff
Jeff - please read the extended 'Edit' at the end of my report - it's all about mid and treble which is where I noticed the most difference with the 5509.
post #2313 of 2653
Originally Posted by kbarnes701 View Post
jeff - please read the extended 'edit' at the end of my report - it's all about mid and treble which is where i noticed the most difference with the 5509.
Yep, and I think you have another level up in store with a Pro calibration.
post #2314 of 2653
yep, and i think you have another level up in store with a pro calibration.
woot!!!
post #2315 of 2653
fun
post #2316 of 2653
Originally Posted by Theresa View Post
fun
It will be when I eventually get the Pro kit - I have to use the Ethernet port, which usually, for me, spells disaster.
post #2317 of 2653
Disaster in what way? I used the ethernet port to update the firmware and it went smoothly. Quite a difference from the UMC-1 which my computer wouldn't recognize.
post #2318 of 2653
Hi Keith,
That's odd. I've done all of my firmware updates via ethernet, plus all of the inet radio functions, and Netflix streaming via Roku without ever experiencing any problems.
A pro installer friend claims that many of the problems that he's encountered are attributed to substandard quality modems, routers, switches, and the like.
Just some food for thought.
Cheers,
SB
post #2319 of 2653
Keith,
You mentioned having to wait for 5509 firmware update to enable pro capability. Do you, or anyone else, know if the 5508 (which I have) is ready to go with pro or is it needing fw also?
I would really like to give pro a go () but I'm hesitating with the cost. If I lived where there were more people interested, I would propose a "pro club" where several people could share the cost of the hardware and each buy a license for their unit.
post #2320 of 2653
No problem running Audyssey Pro with the 5508.
post #2321 of 2653
Initially I had a problem where the Pro did not connect. Switched to dynamic IP on the 5508, as Luke suggested, and it has worked ever since.
post #2322 of 2653
Maybe disaster is too strong - I mean that I often have problems whenever networking is involved, especially if Windows is the OS. I am hoping I don't encounter these problems when I get the Pro kit. If I do, I know there are plenty of people here who understand the issues and who will generously give their time to help me...
post #2323 of 2653
I should start collecting these tips I think...
I am quite excited to get Pro now, in January when the FW becomes available for the 5509.
post #2324 of 2653
Originally Posted by SpotcheckBilly View Post
Hi Keith,
Cheers,
SB
The problem is me not the equipment, I think, SB. If networking is involved, I usually go into panic or WTF mode!
post #2325 of 2653
Drowning in packets...
post #2326 of 2653
I know where to look for the lifeline though
post #2327 of 2653
Keith, has it been established that the 5507 and 5509 are identical WRT internal audio circuitry?
post #2328 of 2653
I don't know, Jeff. There are a few operational and feature differences, an extra DSP mode or two, XT32 of course, possibly different DACs etc - whether that will warrant different circuitry I don't know. Why do you ask?
post #2329 of 2653
Keith,
If they are the same, then all of the improvements you are hearing can be attributed to XT 32.
Jeff
post #2330 of 2653
I doubt they are identical but you can easily establish whether the non-Audyssey aspect sounds the same by including an A/B of the units with Audyssey set to Off and all other settings identical.
post #2331 of 2653
Keith,
Jeff
Ah yes, I see where you are coming from now (there ought to be an acronym for that - ISWYACF now LOL). I suspect you are right - the differences between the two are minor in terms of spec. There is the (small) possibility that the theoretical superiority of separating the processor side from the power amp side might make an audible difference - but I doubt it TBH. If it does it will be *very* subtle and some of the differences I am hearing are subtle, but not *that* subtle IYKWIM. The filter resolution for the satellites with XT is, IIRC, 16. With XT32 it's 512 - that is a huge difference and it must have some audible benefits or why bother? So that is me taking 120 words to say "I agree, Jeff".
post #2332 of 2653
I think that the difference that would be heard between the pre-pro and the receiver is having a more powerful amp when using a pre-pro depending on the sensitivity of the speaker's of course. Since you are using the same amps the difference would be slight if any at all except for the effects of XT32. As someone with inefficient speakers I noticed such a difference when I went from my Yamaha's amps to the Emos.
post #2333 of 2653
That wouldn't apply to me though, as you say, because I am using the same amps now as I was when I had the 5007 (use as a pre-pro). Any differences I am hearing must be differences between the 5007 pre-pro section and the 5509. I suspect Jeff is right - it's XT32 vs XT for the satellites.
Yes, we are in agreement. For speakers of below average efficiency, external power makes a huge difference.
post #2334 of 2653
Attachment 229483
Hi guys, just a Quick question, should I tilt the speaker forward/down,aiming the MLP?
post #2335 of 2653
yes
post #2336 of 2653
Thx, ;-)
post #2337 of 2653
yw
post #2338 of 2653
xt32 might not improve what you hear from a sat perspective I would say local content from dvd/rbrd and stored media may see the benefit more and more..
post #2339 of 2653
Originally Posted by runnernorth View Post
Attachment 229483
Looking good...
post #2340 of 2653
Well, it's a matter of taste/gender, but we, men, likes it, don't we Keith .... :-)
Hope I'll have the time tomorrow to rerun Audyssey xt32, but first I need to put on my running shoes, and breathe some fresh air;-)
Have a nice evening
