Originally Posted by
runnernorth
Oh, that's another thing, my smart power strip can only supply about 300watt, and my amp is using 1300-1400 watt, so this solution doesn't work for me.
is there something else you can plug into the smart strip master socket that is always in use when your system is powered? Anything that draws sufficient current to trip the slave sockets will work - monitor, source component etc. I use my monitor but then my smart strip can supply up to 3kW. Maybe a new smart strip with a higher spec?
runnernorth
Could I use a smart power strip with USB signal, attached to the USB port on the back of the AVP?
Kindly
Jan
I doubt if it would supply enough current to power up the slaves. The way these things work is that the current drain from the master socket has to be enough to trip the slaves. USB ports only supply 5 volts. Not sure how you would connect it either. I use a Harmony 1100 remote to turn the system on so everything comes on with one button press - as soon as the monitor powers up, (which is attached to the master socket) then it operates the Slaves which then power on the fans and a small lamp (my gear is in a closet outside the viewing room). The reverse happens when I power down the system.
You can get USB PC fans which plug directly into the USB port and these will switch on and off with the AVR as the USB ports power up and down with the unit. The only slight drawback there is that because the ports only supply 5 volts, the fans tend to run slower than 12v powered fans and thus the cooling effect is reduced. It may still be enough for your purpose though. In fact, you can use any 12V PC fans and connect them to the USB ports simply by stripping the connector off and attaching the red and black wires to the red and black wires of a an old USB lead that has had the plug removed at one end.
