Originally Posted by CDJayRFU
Quick question; I had the 886 prior to the 5508 and I can't seem to work out how to check on the status of DRC with TrueHD audio from Blu-ray. Most will remember the fuss around Iron Man (which I imported from the States) automatically switching the DRC on with a notable reduction in dynamics. On the 886 I was easily able to monitor and defeat the forced DRC but I can't for the life of me work out how to do the same on the 5508.
Any ideas?
Cheers!
CDJay
Any ideas?
Cheers!
CDJay
The settings for the Late Night function for the 5508 are discussed on page 63 of the 5508 manual. I remember the issue with Iron Man as I had an issue with that title as well. I own the 886 and I have a discrete code for the Late Night setting for my Harmony remote. I'm not sure if there are any discrete codes available for the 5508. If there are discrete codes available they are worth seeking out. Having the many codes on my Harmony makes operating my 886 so much easier.
Bill
). As would the option to convince the unit to ignore any calls for changes to DRC by media (Late Night: Off (Forced)).
. It indicates up to models from 2010 so I'm not sure if the codes will work for the 5508/9. Hopefully they will work fine.
