Originally Posted by Yves Smolders
As a long time Denon user, I have a question about PR-SC5508 - and Onkyo in general.
Denon remembers surround modes based not only on input, but also audio format.
For example I'm having a PS3 on one of the inputs, and it automatically does the following (because I set it once)
* 2 channel 176khz in (PS3 upsampling for CD's) - Direct
* 5.1 channel LPCM - Audissey engaged
* 2 channel 48khz - Audissey engaged + prologic decoding
This is very handy as I never have to get the remote and change surround parameters.
Does Onkyo have a similar system?
Hi Yves,
The Onkyo has a similar function.
Here is an excerpt from page 58 of the manual describing the Listening Mode Preset function.
You can assign a default listening mode to each input
source that will be selected automatically when you select
each input source. For example, you can set the default listening
mode to be used with Dolby Digital input signals.
You can select other listening modes during playback, but
the mode specified here will be resumed once the AV controller
has been set to Standby.
However, for Audyssey it is either on or off for all applicable listening modes.
For certain listening modes, such as Direct and Pure Audio, Audyssey is disabled.
For other listening modes, say Stereo, if you had previously decided to enable Audyssey, you couldn't preset the Stereo listening mode for no Audyssey if you enabled it for other listening modes. You would have to manually go into the Audyssey menus and turn it off.
The manual goes on to explain how the preset function works. In summary, you first select the Input Source Device, i.e. BD/DVD, VCR/DVR, etc. Then you select each Input Signal Format, i.e. Analog/PCM, 2ch Source, etc., and for each combination of Input Source Device and Input Signal Format you have the option of selecting from many available Listening Modes. You can also opt to select “Last Valid” for the last permited Listening Mode for the source format, or “Straight Decode” which means that no additional processing is applied to the input, it just decodes the signal.
Larry
