AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Yamaha RX-A1000/RX-A2000/RX-A3000 thread
"Official" Yamaha RX-A1000/RX-A2000/RX-A3000 thread - Page 150
post #4471 of 8515
Are you guys using the different Movie DSP modes like Adventure, Spectacle, Sci-fi and General/Drama.
Do you actually prefer one over the other and do you find that they sound different ?
post #4472 of 8515
I don't own an "aventage" series but in my RX-V1800 I use Spectacle for movies, I like the sound stage it produces. Adventure comes in second place and Sci-fi in third because to me it creates some sort of echo effect. Try to listen to a specific movie scene with each DSP mode until you find the one you really like.
post #4473 of 8515
Originally Posted by SAVholic View Post
I don't own an advantage series but in my RX-V1800 I use Spectacle for movies, I like the sound stage it produces. Adventure comes in second place and Sci-fi in third because to me it creates some sort of echo effect. Try to listen to a specific movie scene with each DSP mode until you find the one you really like.
Interesting, I own a V1800 and soon to be A3000. I've never tried the DSP modes, maybe I don't know what I'm missing. I will certainly try them out.
post #4474 of 8515
Originally Posted by Mike Lang View Post
Reminder: This is AVS...MSRP price talk only.
So we can't even post discount codes to help others out? Even if we don't discuss the price specifically? If that's the case, you missed a few more posts above that need to be cleaned up.
post #4475 of 8515
Originally Posted by mjf_uk View Post
The so called improvements for the 1000/2000/3000 to 1010/2010/3010 are very small in reality, but for some reason Yamaha have decided to introduce huge price increases. If they want to continue to lose customers, then they are going the right way about it.
Actually the 1000/2000/3000were less expensive than the models they replaced
I didn't think they were jumping to Z7 price levels
I don't even consider Z9 and Z11...as those were at a complete other level of quality that seems to have died with those model discontinuation
Warren
post #4476 of 8515
Just be discrete and state the vendor and the discount code..and mention a "great deal"
I think you will be fine and others will thank you for your information
Warren
post #4477 of 8515
Originally Posted by ebug View Post
How much is the reduced price? Thanks
Not nearly as much as the Electronics Expo deal
Unless you just want to buy from B&M I would suggest you go for the Expo deal
It seems very compelling
Warren
post #4478 of 8515
Originally Posted by turnne1 View Post
The A3000 is also now reduced( on clearance) at Magnolia Home Theater( Best Buy)
Warren
I tried to look up either the A2000 or A3000 on Best Buys Magnolia web site and they only show the A1000? I also went to the local Best Buy Magnolia show room and also they only had the A1000.
post #4479 of 8515
Not in the UK they weren't.
RX-V3900 - £1500
RX-V3067 (A3000) - £1500
RX-V1900 - £1000
RX-V2067 (A2000) - £1100
RX-V1065 - £700
RX-V1067 (A1000) - £850
post #4480 of 8515
Warren
That's all that I did and my post was removed. That's why I was asking so I know for sure and not cause any issues.
post #4481 of 8515
Ok. Let's be discreet on prices. So, I just called EE and Newegg deal is better by about 10 boxes of carry out pizzas, or 50 loaves of bread or 256 lbs of bananas or 16 lbs beef tenderloin or 303 pcs of bone-in chicken wings. Thinking about it, that's a lot of food! Multiply that for a A2000 or A3000, then you can feed a community. I just lost my appetite for an upgrade. My Yamaha V765 is staying.
post #4482 of 8515
Originally Posted by SoundChex View Post
Announced one year ago. Until the last year or two, Yamaha's recent practice had been to run an annual product refresh cycle. There was a longer break between the x63 and x65 model ranges than usual, plus Yamaha numbering jumped from x67 models to x71 (skipping a likely numbered x69 sequence). So we might guess they dropped one annual cycle. The intervals between the x65, x67, and x71 ranges have been more 'regular' but perhaps with fewer real innovations. This might presage an era of regular but more incremental model changes...?
I've been out of the market for a few years, is it still the same process...announcement at january's CES....hits stores around aug/sept?
post #4483 of 8515
Originally Posted by garypen View Post
I'm not sure if Logitech can use what is written in that spreadsheet. If so, great.
But, what I did was use the Yamaha remote to generate a signal for each extended command, and have the Harmony learn it from there.
To create the IR signal from the Yamaha remote, press "setup", scroll up to "EX-IR", and press Enter.
Use the direction keys to change the existing hex entry to match the entry from the "code" column for the specific function you want. If you need to enter four digits, scroll up on the dash in that group's field, and it will change from two to four digits.
Once the code is entered, press "enter", and it will transmit. Make sure to have the Harmony ready to learn before you press enter.
I finally got around to trying this and it worked flawlessly with the Harmony One. I thought I missed it in the Yamaha manual but apparently Yamaha didn't want to disseminate the info to us hoi polloi: "Extended IR code mode. This feature is for the authorized custom installers only." However, it looks like garypen has duly authorized us as custom installers.
post #4484 of 8515
Low- plus some mid-priced AVRs announced 'near' CES (in Jan) . . . available two to six months later. Remaining mid- plus premium-priced AVRs announced 'before CEDIA' (Sept) . . . available (approx) August through December.
post #4485 of 8515
Hi all, trying to decide if I should jump on the Newegg deal or wait... For the 2010 or for price drops. Have an onkyo sr805 which I love, but no 3d is driving me nuts! any advice? I know this is the million dollar question! Looks like the 2010 has 9.2, and a bit more power. Also, what do I do with my 805? Keep it? Sell it? I can't imagine it's worth more than a couple hundred at this point.
Appreciate it.
Matt
post #4486 of 8515
Appreciate it.
Matt
I use my old RX-V3800 in the bedroom with a 2.1 speaker setup.
post #4487 of 8515
Just grabbed the A2000 deal on the egg a little while ago. Can't wait! Thank you to everyone who got busted yesterday with the deals! It made the difference between getting this and a Denon 2312CI. I think I'm going to be a lot happier.
post #4488 of 8515
Got my RX-A2000 from Electronics Expo 976 delivered.
post #4489 of 8515
I'm in the market for a new AVR to replace my Sony STR-DA5500ES. Am highly considering the RX-A3010 and was curious what the difference is. Looks like the main differences seem to be the UI changes, more pre-outs and the added power (9.2) to provide powering 2 presence speakers without external amplification. I've attached a printout of the comparison chart I used from Yamaha's site.
rx-a3000 - rx-a3010 comparison chart.pdf 398.6318359375k . file
post #4490 of 8515
Sorry, been awhile since I have been here.
post #4491 of 8515
Yes, you pretty much have the differences covered. I've been carefully comparing them for a week. The only feature I really cared about was the improved G.U.I. and mostly just because you can turn off the volume display. But, I ordered an A3000 yesterday because of the great deals going on. I think if you need the extra channels the A3010 is worth waiting for.
post #4492 of 8515
Yeah, I almost pulled the trigger but I have to be able to turn off everything on the front display. All my current equipment can have their displays turned off so I love not having them be distracting. But I also liked the ability to power one set of presence speakers without buying an external amp so I decided to wait.
Sorry for going OT a little, but have any of you used a receiver with multi-channel inputs as an external amp for another AVR? If I keep my current AVR, I suppose I could use it as an amp for other preouts from another AVR, say the rear presence from an A30xx for example. However, unlike an amp, the volume on the AVR acting as an amp controls, well, the level. So, if you've used this type of set up, is there a rule of thumb to setting the volume on the "receiving" AVR?
post #4493 of 8515
We may be talking about two different things. I'm talking about the volume display that shows up on the TV, I believe you are talking about the display on the AVR, which both the A3000 and A3010 can be dimmed or maybe shut off.
post #4494 of 8515
Yes, you're right, but I did read about the volume control on the GUI in someone's earlier post which would be annoying. I actually hate the fact that I can't turn off on-screen icons like in the old days. I remember several of my DVD players allowed me to turn off all on-screen icons. I wish that is an option on any unit, be it an AVR, a BD player or whatever, as long as they have UI elements.
post #4495 of 8515
Well, bit the bullet with the newegg deal. Just hope newegg doesn't have the 2010 discounted right after release! Can't wait to get it!
post #4496 of 8515
Hi, on my A3000, I have tried and played with most of the DSP's. With Movies in general, I like the Standard mode. With live shows and concerts, the Vanguard or Roxy Theater is not bad. However, I normally just leave the processing off. Sometimes I just switch to "Pure Direct" Mode. I don't really like to add to the sounds... prefer to listen to them as it was meant to be. Some older material sure shines with the DSP, though.
Have fun experimenting with your unit, its the only way you'll ever see how it shines.
chapper.
post #4497 of 8515
Received my 2000 and have have put it through many trials. I have hooked up the Ethernet and am able to get my wife's laptop connected with WINDOWS 7 and play MP3's etc. My computer running XP I am not getting so lucky. Does the 2000 only do Win7 and not XP. Any help would be awesome.
post #4498 of 8515
Make sure you have Windows Media Player 11 installed and you've enabled media sharing.
post #4499 of 8515
DLNA is a standard, so with the right software it shouldn't be a problem. I did a quick search and found this. It talks about how to make XP and Vista systems into DLNA servers.
post #4500 of 8515
I was under the impression that it has to be windows 7....windows xp wont work as far as I know....a couple of friends had the same issue...as soon as they upgraded to a windows 7 box everything worked correctly
