Originally Posted by joeyvaz
RX-A1000 connected in a 5.1 setup, with a PS3 slim set to bitstream as my blu-ray source. I can't get DTS-HD to display on the receiver's display. I have checked the DTS-HD option in the movies I tried, but no dice. Am I missing something?
Secondly, YPAO set my Emotiva 6.2/6.3 fronts to small, 80hz XO, and it detected my sub. With my last 2 receivers (Pioneer vsx-1121 and Onkyo 809), the sub was MUCH fuller. YPAO set my sub to -2.0db with the sub's dial set to ~40%. Sub is in the exact same position it was with my previous 2 receivers.
Thirdly, after reading through the last 60 or so pages of this thread, I haven't read of anyone having this issue. My surround speakers are very low. YPAO set them to +1.5db, but they are almost non existant during movies. They are Emotiva erd-1 dipoles. Still working on level matching the fronts and rears to 75db as I have in the past, but that part isn't as easy as my past receivers. The test tone is extremely low, unless I'm missing something.
****If anyone is wondering, the full 5. speakers in my setup are 4ohm Emotivas. After 5-6 straight hours of playing jazz and a few movies, the receiver never ran hot or went into protect mode. They are all 89db in sensitivity. So they aren't too inefficient as far as most 4ohm speakers are concerned.
You need a more powerful amp. My side surrounds are 8ohm and 90db sensitive, and they require a +3db boost (twice the power, afaik) to level match, compared to my mains which are 97db sensitive 8ohm..
Since all your speakers are even lower sensitivity, this sounds entirely normal. Buy a more powerful amp or receiver.
