AVS › AVS Forum › Video Components › Home Theater Computers › Official Dell Zino 410 HTPC
Official Dell Zino 410 HTPC - Page 9
post #241 of 793
Originally Posted by David Scott View Post
got any more coupons? that one is redeemed already...thanks!
If you are a AAA member then go to www.aaa.com/dell. How will have to sign into your online AAA account but then you get either coupon codes or special deals on zinos. That's where I got the coupon code.
post #242 of 793
I always forget to check with AAA, doh...ordered one last night, the $649 special as I figure if I got the $499 configuration it would cost me about the same to put my own BD drive in. Also added the remote so I don't have to order the sensor later, plus the trackball keyboard. I will let everyone know how it performs once I get it all hooked up and configured properly. My main uses will be playback of MKV's of blu-ray and high resolution suround sound music.
post #243 of 793
Can anyone who has setup MKV playback on their Zino 410 let me know whether the following file plays at the correct frame rate?
http://www.megaupload.com/?d=M0AJU408
This is the 10 Mbps 1080p60 clip, but it plays at only 20 - 30 fps in MPC-HC (latest SVN version) for me. I am wondering what the issue is.. On the other hand, if someone is able to confirm it plays well, I would love to hear about the config (MPC-HC version / splitter used etc.)
post #244 of 793
I am actually a Dell employee so I get a nice little 17% discount on any of these bad boys. I was debating on weather or not to build an HTPC or buy one. I was leaning towards the build side, but this little baby would fit perfectly in my existing setup and go great with my other components.
The only thing I would be doing is watching locally saved video, the max being 1080p mkvs, maybe listening to streaming music, possibly streaming stuff from youtube or hulu occasionally. No gaming or anything else. I strictly want to sit this thing under my TV and have it playback video. Would this be a good buy? What would be the advantage of going with the quad vs the dual core for my needs?
post #245 of 793
Have you tried it using VLC. Maybe its a MPC issue
post #246 of 793
VLC with or without GPU acceleration just 'hangs' after displaying a few frames. This is a pretty complicated clip.. with 8 reference frames (above the L4.1 threshold) and also 60 fps. Funny thing is that it plays pretty well on a desktop HTPC with the ATI 5570 (but the host processor is more powerful (i5) in that).
Maybe Java Jack or R1Budha can chime in with their experience with the above file (in case they have setup MKV playback)
Edit:
Installed Win7Codecs (Shark007), and the file plays without dropped frames in WMP with Shark007 suggested settings. However, CPU usage is at 80%. In MPC-HC, the decoder is using 5450 DXVA and dropping frames like crazy. Is the Mobility 5450 expected to be this weak? I haven't played around with a Mobility 5450 before, so any inputs from users familiar with the GPU will be deeply appreciated.
post #247 of 793
just for laughs, i tried to play it on my popbox, and it played fine, no audio though... I don't know how to measure at what rate it played the file though...
post #248 of 793
David,
I also ordered the $649 with the Quad core since I didn't want to have to fool with adding a Blue Ray drive and waiting for the IR sensor. I was able to use the $35 AAA coupon, $100 gift card from Discover, and another $30 coming my way for the 5% cashback. Regardless, it will be a good addition to the family room as we will now be able to watch online videos and videos stored on my NAS. I can't wait. I also ordered the Media Remote to hopefully get the IR sensor.
post #249 of 793
How are you guys using the AAA coupon? I can't seem to find it anywhere... (I'm also a AAA member)
post #250 of 793
Using VLC without GPU acceleration I dropped 4 frames (3 frames at the very beginning) . Using GPU acceleration I was dropping frames all over the place. This was using Intel 2 Duo E8400 @ 3.00 GHz and a 9600 GT.
The clip also played fine my WD HD Live.
post #251 of 793
Many people dedicate HTPCs for ripping their Blu-Rays and DVDs. Re-encoding is a required functionality for that. I review PCs on what the readership wants
People do all sorts of things, and to some extent there should be diversity, but sometimes there should be standard/more correct ways of doing things. Wanting fast encoding on an HTPC indicates that either you don't have a more powerful PC than the HTPC, or you have one but it's not networked properly so for some reason it's not convenient to rip/encode on it.
I still think the quad core + 5450 is the best option to go with even if you are not planning to play Blu-Rays right now. That way, this HTPC will be a 2 - 3 year investment. If you get the lower end config you are probably going to upgrade next year itself Just my 2 cents.. your particular situation might call for a different choice.
The cheapest option wouldn't have have a problem Blu-Ray bitrates, would it?
The main disadvantage of quad core/discrete graphics would be much higher power consumption. It's very difficult to have a powerful PC (quad core + discrete graphics) that is inaudible in a silent room, even if you build yourself.
Anyone have power consumption measurements BTW?
post #252 of 793
For the highest end config, at idle, it is approx 29 W and at load it is 60W (load = Prime95 loading all 4 cores + Furmark loading up the GPU fully).
Bitrates are almost never an issue in any HTPC. It is the complicated encoding characteristics / frame rates (sometimes) which are the issue.
post #253 of 793
That's reasonable for what it is. Still it will be noisy, and probably impossible to mod for silence at that power level in a small box.
Anyone know the consumption for one of the single/dual cores with integrated gfx?
I don't think I'll jump on this though, I'll wait for Fusion to upgrade (in particular Llano, the 32nm CPU+GPU due in 1H 2011).
post #254 of 793
Strangely, both the dual and quad core variants are rated at the same TDP of 25W. The 5450 and the chipset GPU probably differ maximum by 10 W. (not sure about this.
By the way, the unit is pretty silent even at load. I have experienced the fan noise at load in both the ASRock Vision 3D and the Zino 410, and I would actually say the Zino 410 is less noisy. Professional measurement of the sound level of the Vision 3D was around 35 dB, and this one should be even lesser.
post #255 of 793
I logged into www.aaa.com/dell about 2 months ago and got the coupon code when the Zino 400 was still around. Luckily I saved it and was able to still use in on the Zino 410. It appears that now all you get is list of discounted systems and not a coupon code to use on any system. I beleive their deals change over time. As it did for me over the last 2 months.
Check www.retailmenot.com every so often for coupon codes.
post #256 of 793
Yeah, I'm only getting the 'discounted' systems now as well. Bummer. I'll have to keep an eye out on the AAA and the retailmenot sites.
post #257 of 793
Hi,
I'm very interested in buying the high-end version of the Zino. I know it's not really needed for htpc purpusses only but I also want to use the machine as a hyper-v server to build a small virtual lab environment.
So, the question that's keeping me busy:
- Will the combination HTPC and Hyper-V perform on the high-end, 8GB ram configuration? (I will be running max 4 to 5 virtual servers cuncurrent).
@jakmal: Will there be an anandtech review for this machine and when do you think it will appear on the website? Will you cover a comparison with the Asrock Vision 3D?
Hope anyone can help!
post #258 of 793
Originally Posted by SpeedyV View Post
Hi,
The processor is a mobile processor meant to be usually used for laptops. I am not sure about the processor requirements for Hyper-V, but it does sound like something suited for a desktop processor. Disclaimer : Never used Hyper-V or studied its requirements before ; Other knowledgeable members should chime in.
Yes, There will be a review and a comparison with the Core 100 / Vision 3D. Initial benchmarking / analysis reveals that the high end config is better than the Core 100 but not as good as the Vision 3D. I hope to get the detailed review out of the door by next weekend.
post #259 of 793
Been looking hard at Roku and AppleTV, but Im wondering if the 410 with the best ATI card isnt a better choice.
Looking for something to hoop up to my Duo/58" plasma to handle all web available HD, like Hulu, Nflix, Amazon VOD, CBS.com Free HD episodes.
You guys think the 410 is a good choice to do everything? My issue with other boxes are there is not a one size fits all, while it seems a HTPC would do it all. Watching free HD episodes of CBS.com is a pretty cool deal if it would work.
post #260 of 793
Yes, but this is just an upper bound, chosen for some inscrutable marketing reason.
That's good, but 35db is not good for a non-gaming PC, so how much less is important. Looking at the earlier pics of the internals, there is just one fan, so if you took a low power version, replaced the fan if necessary, and added something to dampen/isolate the hard drive somewhat, or better replaced it with an SSD, you could have a very quiet system.
post #261 of 793
Jakmal thanks for your reply, I hope someone can shed some light in the dark concerning my hyper-v question.
post #262 of 793
Actually, marketing does not determine the TDP of our processors. TDP is determined by our engineering and validation teams based upon extensive testing.
post #263 of 793
I saw this in the Zino 400 thread.
Originally Posted by Pauloxxi View Post
I bought the Dell Zino 410.. I'm a kind of desapointed, since I payd almost $500, but the HDMI does not support the 5.1, so I also need to use the optical, which is already occupied in my receiver.... Why these guys at Dell use a HDMI without 5.1 capability....
Also... do you recommend formating this thing just to get rid of the Dell garbage out of that and reinstalling a clean Win-7?
I've been following this thread but I guess I haven't been paying enough attention, is the above really true?
post #264 of 793
Originally Posted by David James View Post
I saw this in the Zino 400 thread.I've been following this thread but I guess I haven't been paying enough attention, is the above really true?
The 5450 model supports 7.1 LPCM and also HD audio bitstreaming. Personally verified
post #265 of 793
not only is it wrong, it's very wrong.
i have my system up and running and have now for a few weeks.
it plays not only 5.1 from DVD's via hdmi, it also plays all HD audio sources via HDMI as well.
my setup is as follows:
Dell ZinoHD 410->Sony STR-DN1000->Sony 42" LCD
and this did not require any setup by me as it was configured for this "out of the box" from Dell.
The only setup i did was the speaker configuration within Windows to tell it i had a 5.1 setup.
post #266 of 793
Thank you gentlemen for your responses.
post #267 of 793
CNET has reviewed the Zino HD with Quad core, HD540, blue-ray, etc.
http://reviews.cnet.com/desktops/del...t;get-selector
post #268 of 793
But they are not measurements. They are chosen from a set of numbers - 25W, 45W, 65W, 95W etc. that are clearly not measurements, and I'm sure this set of possibilities not chosen by engineers. Presumably this set is chosen by marketing, so people don't get confused by more exact numbers, and so they don't understand the tradeoffs involved in picking a higher processor speed. This is not a criticism.
To guage power consumption you need measurements; TDP only gives you a very vague bracket for load power consumption.
post #269 of 793
The CNET review makes a pretty good case for getting the Gateway SX2850-33 over the Zino. Hmmm... decisions decisions...
post #270 of 793
The Gateway (I think the previous version) was the top of my list before the 410 came out. It really depends on your requirements, mine are simple and at this point the low end 410 looks like it's "good enough" for the next couple/three of years, which is all I buy technology for anymore anyway.
