First this is the set-up I ordered for $679.00
AMD Phenom II X4 P940 Quad Core 2MB
1TB Hard Drive
6GB Ram
ATI Mobility Radeon HD 5450 Graphics Card
Blu-Ray DVD/CD Burner
THX TruStudio Sound
And of course all the other stuff that comes standard including the wireless setup and remote.
This should be arriving Wednesday...I do have one question.
I have an older Onkyo receiver and I use with with a Bose 6.1 Surrond speaker system (1 output to the sub and the sub sends the sound to all the speakers). My receiver, being older, only has 1 HDMI input and no outputs so currently I run my ATT Uverse Cable Box and PS3 to my Epson 8350 Projector via HDMI and then run the regular red/white cables to my receiver for audio. Audio works great and I get full audio sound. I didnt think about this when I ordered the Zino...Im assuming it has not only the HDMI output but also the red/White audio plugs. Do you all think that I will be able to maintain the same setup as I do with the PS3...with the HDMI going from Zino to projector for video and the red/whites to the receiver for audio and still maintain the full surrond sound? I am assuming that since I can do it with the PS3 that it will also work with the Zino...Im just trying to avoid a replacing a receiver that works great.
I think that because the sound all goes to the sub and the sub takes care of audio placement to the correct speakers that I should be ok...I purchased this so I can play all my DVD's and Blu-Rays via the HTPC (I put them all on external hard drives) and I want to maintain the true surround sound.
any ideas on this?
(Edit - Just realized it has an Digitial Optical port for audio - if that is the case I do have an extra optical port for audio in my receiver and I should be ok)
1TB Hard Drive
6GB Ram
THX TruStudio Sound
any ideas on this?
