post #1 of 1
How are the distribution amps linked for the source inputs? I have been told only 6 sources are available to all the downstream amps. How is the input signal propagated from the primary amp to the downstream amps? I suppose a Y cable from the input sources could do the trick for 2 amps but what about 3-6?
Is it a better Idea to use the line level out on zones 1 and 2 to cascade?
What about programming? is there a default macro to do all the proper switching to get input 1 on output 9 or 36?
Seem like a pretty convoluted way to do things or am I completely missing something... RNet????
