Hi,
I just did a rough setup on my Cine 7 (with 694 hours) to get familiar with the controls. It's bin a few years since I last worked with crt projectors.
I already got a pretty nice image but also some problems:
The image is continuously moving/shaking. Like someone is zooming in and out a tiny bit, constantly. The convergence stays intact.
When I look into the lenses I see on the bottom of the Phosphor some rapidly moving lines. On all the tubes. These lines don't dissapear when I use blanking. The lines look somewhat like this:
The Barco is hooked up via component on my TViX which is configured for 1080i/60hz. I tried different resolutions but the problem stays. I tried lowering the contrast and/or brightness but the problem stays.
It doesn't matter if I use a external source or a internal test pattern. The problems are the same.
Does this sound familiar to somebody?
Edit: I just tried deleting all memory blocks and set everything to mid positions. It didn't solve the problem.
LOL
