AVS › AVS Forum › Audio › Soundbars › zvox 325 or zvox mini?
post #1 of 3
I have a small room and i just bought a 32 inch sony LCD. I need some simulated surround sound speakers. Which would be the most practical solution for my situation?
post #2 of 3
The 325 will give you a wider bigger range, but it has a larger footprint. I just got a 550 and I'm loving it. I have it beneath the base of an LG47" and it looks like it's part of the TV base. Sound is awesome.. full range with deep tight base and excellent vocal intelligability
post #3 of 3
where did you get the 550
  Back to Forum: Soundbars
