Got my card installed and working. I'm using it in gateway sx2840 and card wouldn't fit into x1 slot. Had to use x16 slot for the card to fit. x1 slot required removal of dvd drive. Also the bracket of the card is a bit off so when the card is installed it doesn't sit completely in the PCIe slot without a bit of maneuvering.
So far everything is running smooth except my MCE lost its sleeping ability. It now decides to bluescreen after going to sleep. Still trying to track down the issue. So far minidump file is pointing to USB timeout issue. Weird thing is that only thing that got installed is ceton tuner so I'm guessing its the unused TA service that is causing the problem.
Without the sleep issue, everything else is running smoothly. Quality is as good as my Tivo. Gateway box so far is handling the job very nicely. Although with constant activity its running a bit hot. Need to figure out how to cool it down.
Here are few pictures of the card
