HDMI Splitter?
post #1 of 4
I am thinking of purchasing an HDMI splitter for recording my gameplay on the xbox 360, my setup i'm thinking of having is this:
Xbox 360> HDMI splitter (Input via HDMI cord)
HDMI splitter output1> LCD monitor-DVI-D (Input via HDMI to DVI-D cord)
HDMI splitter output2> Capture card-HDMI (Input via HDMI to HDMI cord)
Now the main concern i'm having is if the HDMI splitter can handle the HDMI to DVI-D because I purchased the Blackmagic Intensity Pro a while ago and it didn't work HDMI to DVI-D because something about the BMI pro didn't output RGB signal or something...
So i'm wondering if this splitter:
http://www.tigerdirect.ca/applicatio...03378&CatId=81
Will this setup work?
Also will the HDMI splitter cause Input lag?
post #2 of 4
I don't know if this will answer your question, but I believe it should work.
post #3 of 4
Ya, I know HDMI to DVI-D works directly from the xbox 360 to the LCD monitor but I don't know if it will work if I try to go HDMI to DVI-D from the HDMI splitter
post #4 of 4
ya it works, a friend has his set up this way and it works fine with a monoprice switch.
  Back to Forum: General Gaming Help
