I recently purchased a Panasonic international DVDR. It's mainly meant for the European market(SCART connectors etc.) but also works in the US to record a NTSC line input from it's S-video or composite inputs. The problem I'm having is when I feed the DVDR a NTSC line output(from a DVD player, VCR or Tivo HD etc.) the recordings(or even line input feed through(from HD outputs)) look too light.
US Panasonics have a line input DARK LEVEL adjustment which I always set to DARKER(instead of the other option LIGHTER). The problem is this international DVDR doesn't seem to have that particular option and it's more like the US Panasonics set to LIGHTER(which have light darks).
Now I could just adjust my TVs brightness to compensate but I want my NTSC recorded DVDs to be able to be played on a properly calibrated US TV. I've read various articles about 0 IRE vs 7.5 IRE(apparently the US uses 7.5 while Europe(the rest of the world??) uses 0. Could this be what's causing my problem and if so is their a easy remedy? If I'm copying a DVD via line inputs, some DVD players have brightness adjustments that may be able to overcome the overly bright recordings(I'd set my DVD player to output a overly dark picture knowing the recorder would up the brightness) but many devices don't have output brightness adjustments(like my Tivo HD, VCR etc.) how would I handle those?
I'm hoping somebody like sneals2000 or another European poster would know how these international recorders are setup AFA black level. That or someone from the US that's well versed on black levels and international products.
I only ever record NTSC sources which are recorded to DVD as such and played on a US NTSC TV.
(when played on a US player).
Don't get me started on ATSC
