Just a few pictures of what I have been working on lately...not much
When I installed a wall to create a laundry room, I needed to install a 2x6 (ish) wall. Instead of ordering a custom door jamb, I decided to make my own. I bought some preprimed MDF and attached it to the door jamb with biscuit joints and glue. I filled with a wood puddy and sanded smooth.
Here is the jamb after it has been sanded smooth.
And below are a couple odds and ends.
Here is my "clamping" system I devised to hold down the laminate/stair tread bullnose. Just to keep it from wanting to pull away from the base.
Here are a couple pieces of red oak with some samples of stain...red mahogany on the left and ebony on the right...
The stained pieces are after a 180 grit sanding and a couple applications of stain...neither of which my wife likes. She wants a very light stain (which I vetoed) so we are going to try something else.
So yesterday over lunch I stopped by the Woodsmith store and picked up some wood dye.
I dont know exactly how this will turn out. I have never used any wood dyes before, but I am interested in learning. I am hoping we will get a more even darkness...I plan on doing a few more samples this weekend.
Most of the furniture she bought is for the bedroom so that will get assembled soon and the bedroom will be complete.
