Cyclone Cinema Build - Page 18
post #511 of 524
If I understand your situation correctly, it sounds like you are going to need to remove a few boards and replace them. Assuming the subfloor is not also warped, I would cut out a board or two using a chisel or anything you can get your hands on. It doesn't have to be pretty, you just don't want to hurt the adjacent boards. Once you get one out, or even a portion of one, you can usually work out the remaining portion of that board as well any others that are affected without having to pull up the adjacent good boards. It's not fun, and can be time consuming depending on how flat your floor is and what else is holding down the laminate. After that, you put in as many boards as you can using the interlocking mechanism (you might have to slide some in). Again, probably not fun, and probably takes longer than you want if your floor is good and flat. For the last few (one if you can make it work out), you will probably have to cut off the locking tab, and glue it to the adjacent boards. The last time I did this, I was able to leave the tab on one side which allowed for a good glue surface, but I had to cut the other locking tab off. I put a little glue on the edge anyway. Most squeezed out when I pushed the board down, but I figured if any was left, it was better than nothing. I used regular wood glue. And just to clarify, I'm talking about gluing the wood together, not gluing to the floor .
Now, if this is on a wood subfloor, you might even be able to put a few face nails in that last board. The argument there being the floor can't float and you might end up with buckling in the future depending on the layout.
JPA, you posted your message at the same time I was typing mine up. I have a concrete subfloor, so no worries there. Otherwise, it seems like we have the same idea. Thank you very much for taking the time to post a reply!
post #512 of 524
One other thing I thought of. I seem to remember having a couple pieces that WOULD NOT slide into place once locked no matter how much I persuaded them. IIRC, I ended up trimming the locking part of the tab off (a sharp utility knife worked well for this), and putting some glue on those pieces and slid them into place. I ended up with overlapping tabs with glue rather than a locking feature. It's a little hard to describe, but hopefully you follow what I'm getting at. The glue is probably stronger anyway. I would just put something heavy on the pieces you glue to make sure you get a good bond; unless your floor is uneven, in which case you will end up with wood that follows the contour of the subfloor.
Good luck. I think this is one of those cases where the obvious answer is probably right, despite how unpleasant it might be biggrin.gif
post #513 of 524
Well, I haven't been courageous enough to cut up my floor, so the swelled laminate is still untouched. This really is a shameless bump to keep my thread from falling any farther back. But really, I am thinking about building some new speakers, not because I NEED them, more because I am bored and want something to do this winter.
I really like my Statements, especially for music, but have been pondering the idea of building a set of 4pi's or maybe some version of an SEOS. The additional sensitivity would be welcome and I am up for another challenge.
In case people are interested, my wife and I use the theater about as fast as Netflix can send a new BluRay. I was afraid that it might go unused for periods of time, but we have really used it a lot. Football weekends are especially nice when there is nothing else going on. Just wanted to throw this out there for those that are on the fence when trying to decide to build or not.
post #514 of 524
I started a 'build thread' a while ago, hoping it would spur me and keep me accountable. My goal was the SuperBowl, and I'm nowhere near started. eek.gif
post #515 of 524
Brian,
I'm glad to hear that you are getting lot's of use out of the theater!
We are finishing our 2nd full year of use. Despite the novelty wearing off; I am still down there an average of 3 evenings a week (my wife even joins me for at least 2 of those evenings).
Glad to hear you are getting into speaker building. I got the itch as well - and today I received my very first SEOS shipment smile.gifsmile.gif
post #516 of 524
Quick update to keep the ole thread from slipping into obscurity.
Got a few small movie posters for Christmas and finally got around to getting them mounted on the wall.
From afar...
And up close...
post #517 of 524
I got a fun little package in the mail today!
I ordered it at the beginning of January, but it was backordered until the end of Jan. Overall I was impressed with how quickly it arrived considering it was shipped from Hong Kong. I would plan on playing around with it ASAP, but the dedicated theater room became a dedicated play room a week ago, as our first child arrived 10 days early. No more updates for about 18 years.wink.gif
post #518 of 524
Hey Brian. Congratulations on the new baby!! I wonder what Barney and Elmo will look like on that size of screen...
Enjoy the ride as they grow up very fast!
post #519 of 524
I'm getting married this fall, and my goal is to get my space done before I have your problem wink.gifbiggrin.gif
post #520 of 524
Brian - congratulations!
Enjoy as these next years will fly by ...
post #521 of 524
Thanks GWCR. I am glad the build is at a good stopping point so I can enjoy her. I have been following your build, looks like it will turn out nice.
Thanks Nick. Congrats on the upcoming marriage.
Thanks Cuzed. Before I know it she will be all grown up and attending ISU...wink.gif
post #522 of 524
I like the way you think - just enjoy to the Max. Those special years in between
post #523 of 524
So I have had ZERO time to spend in the basement doing calibration, but I have spent plenty of time dreaming about upgrades. Specifically, subwoofers. I can knock out a couple subwoofer boxes much quicker than I can figure out REW, so this is something I can probably do without spending a huge amount of time.
Right now I have a THTLP and a BIC Acoustech H100, neither of which go very low (<25). I am looking to build something that goes to 20 hz or so (lower hopefully). I would keep the THTLP and sell the BIC unless this would cause problems.
Currently I have the BIC sitting on the riser to the side of the couch. I was toying around with the idea of building 1 or two sealed enclosures to fit between the back wall and the back couch. However, the drivers would be firing directly into the back of the couch, is this going to cause a problem? I like being able to locate subs at the front of the room AND the back of the room to try to smooth the response throughout the room.
From my very quick calculations, I have about 9 cubic ft of internal volume available for enclosures that will fit behind the couch.
If firing into the back of the couch is going to be a problem, I can build normal boxes to be located behind the screen, but I lose the placement in the back of the room.
I have this drawn up in sketchup that I can add tomorrow if I am doing a poor job explaining.
Any input is appreciated, specifically:
1. Will it be okay to fire the drivers into the back of the couch without problems?
2. Will I run into problems trying to use the THTLP that goes down to 25hz with a sealed (or ported) sub designed to go lower? Would I be smarter to do something different? I have Audyssey with XT32 if that helps make a recommendation.
post #524 of 524
Hey good to see you posting again!
My 2 cents worth:
For best results - Definitely go with 2 matched subs. I hear good things about folded horns. - but have no experience, cause I am running 3 "almost matched" SVS 16s. You have the perfect AVR for multiple subs (but you already know this).
