AVS › AVS Forum › 3D Central › 3D Source Components › cox, onkyo issues
cox, onkyo issues
post #1 of 14
hello everyone. i need some help/answers. here's what i got. 73'' mitsubishi 2008 735 series w/ 3d adapter 3dc-1000 and cox cablebox dch3416 and my new sr608
if i hook it up.....
cablebox-receiver-tv=works fine
if i hook it up for 3d.....
cablebox-3d adapter-tv= 3d works fine, i watched pga golf today.
if i hook it up 3d this way.....
cablebox-receiver-3d apapter-tv= i get a message "the 3d content protection of your repeater has been compromised. all devices connect to the repeater will not be authorized to receive video over the digital link" then the screen goes green.
i need to hook it up that way so i dont have to keep unplugging it when i wanna use the ps3 in 3d. that passes through fine through the receiver. at first i thought it was cox but they said everything good on their end. im stumped any ideas please??
post #2 of 14
Is your PS3 outputing games in checkerboard format? If yes they do not need to go through the adapter.
Your Onyko is not providing the EDID data from the adapter to your cable box it is proviing it's own EDID data.
post #3 of 14
the ps3 works fine through the receiver and adapter. 3d is great through it .
the cablebox - receiver - adapter - tv is when i have the problem
post #4 of 14
I know that is why I asked what I asked and wrote what I wrote.
post #5 of 14
im sorry but im not sure what your talking about or what is has to do with my cablebox
post #6 of 14
Then ignore my questions and my comments, maybe some one else can help you since I apparently can't.
post #7 of 14
here's the update
called cox and said its onkyo
called onkyo and they said the cablebox is thinking that the 3dc is a recording device which is making the hdcp appear, and was instructed to call motorola.
called motorola and was told that if the cablebox works correctly when hooked up cablebox<3dc
called onkyo back and got a different rep, pretty much said that the problem is that the 3dc-1000 is not hdcp compliant and thats why its not working.
i guess im going to call mitsubishi monday and see what happens from there.
post #8 of 14
Originally Posted by div3r5ity View Post
here's the update
IMO it has to be a bug with the cable STB. People are using the adapter with Blu-ray players and those require HDCP too (so does the PS3 for that matter).
post #9 of 14
its wierd cuz if i plug the cablebox to the receiver then to tv its fine but no 3d
and if i plug the cablebox to the adapter then to tv then its fine with 3d. i dunno
post #10 of 14
here's the update
You are a glutton for punishment, aren't you? If you let them, each rep will tell you it's the other guy's equipment that's at fault. You might want to check the official Onkyo 608 thread in this forum.
post #11 of 14
i have im on there too been reading up
post #12 of 14
well i got everything working! i had to buy 2 hdmi splitters(sewelldirect.com) and an hmdi switch(radioshack auvio) for 3dc adapter and everything is working perfectly.
post #13 of 14
Could you give me more details as I have the same problem with new 1.4 Integra 30.2 AVR and Fios cable and Xbox360 (PS3 works fine). How did you hook up the splitters and switch? The Sewell HDMI 1x2 Splitter v1.3b is out of stock until 11/30/10. Is that the correct one? Thanks.
post #14 of 14
ps3>avr>splitter>tv(input 1)
________splitter>hdmi switch>3dc>tv(input 3)
cablebox>
splitter>avr>tv(input 1)
splitter>hmdi switch>3dc>tv(input 3)
i probably bought the last 2 splitters hahaha. hopefully u understand how i set it up
  Back to Forum: 3D Source Components
