AVS › AVS Forum › 3D Central › 3D Source Components › Which 3D Blu Ray player should I choose?
post #1 of 3
What is the best 3D blu-ray player out there purely for upconverting, 3D picture quality and load times... Just bought the Panny VT 3D plasma and looking at the Blu Rays now....I think based on info ...I like the Panny BDT300 ,Samsung C6900 or the Sony S770 ...
post #2 of 3
I wouldn't say there is a best, but I would go with the Panny since it has dual HDMI outputs.
post #3 of 3
Panny or Samsung 7900 are the best. They both have dual outputs but the Panny supports other 3D format outputs (useless to you though since you have HDMI 1.4).
  Back to Forum: 3D Source Components
