So my front three speakers are large full range things (Vaf Research I66), from what I understand designed to be located away from walls (well thats the typical placement anyhow)
I am toying with the idea of placing them behind an AT screen, which would mean (in my case) they'd be right up against the front wall (they're front ported).
What information do I need to determine if this is a good idea or not?
Polar response charts?
Can any speaker be placed like this if appropriate treatment is done?
Also, assuming this can be done, whats the minimum distance I can have the screen in front of the speakers?
Edit: is this more an issue for the R and L then the center? Its likely my L and R will/can sit outside the screen width (room is 3.8m wide and screen 2.3m), which would mean I could bring them forward
you're more then welcome however.
