Originally Posted by
cyberized
Can you use the DLP Optomas' at the same time as 3D Glasses that send their signal via an Emitter? Do they conflict?
TKS
The signals themselves don't conflict but some members here have found that the DLP Link glasses are reverse synced in comparison to the IR glasses.
This means that if the IR glasses are seeing the left image to the left eye for one frame the DLP Link ones will see the left image to the right eye (which is wrong).
You can't use IR and DLP Link at the same time unless you have a way to reverse the sync of either glasses somehow.
