As I understand it, they are scanning *everything* at 4K, then putting the episodes together digitally. If the 13 seconds is in another box, mislabeled, they will eventually find it as they scan in other reels.
This is merely my hypothesis, but what they probably did was pick these three (four) episodes to put on the sample and grabbed only those reels first. Then, after scanning those, they started scanning in every other episode, in sequential order, one can after the next. This is going on while other crews are piecing together the sampler episodes in the digital space. For all we know, they have scanned two seasons worth of film and they will find the 13 seconds as they scan season three.
If they don't ever find it... so what? They will upconvert their SD source and it will likely still be better than the DVD looks upconverted on home AV gear. At some point, yes, if they are missing entire episodes or something, then it will be up to each consumer to decide what the cut-off is. Hopefully, if something like that does happen, they would also adjust the price accordingly - even if it's only a couple dollars. (probably wishful thinking)
![Star Trek: The Next Generation - Season Three [Blu-ray]](http://cdn.avsforum.com/4/40/50x50px-ZC-40da8d7d_B00B7VZN76-511ma02BkKxL.jpeg)
![Star Trek: The Next Generation Motion Picture Collection (First Contact / Generations / Insurrection / Nemesis) [Blu-ray]](http://cdn.avsforum.com/0/0b/50x50px-ZC-0be8546c_B002I9Z8GW-51Y1Zjf5K7L.jpeg)
![Star Trek: The Complete Original Series (Seasons 1-3) [Blu-ray]](http://cdn.avsforum.com/b/b4/50x50px-ZC-b4815ffc_B002PQ7JQK-51MFX4bllSL.jpeg)
