About a month ago, I started having problems with my Panasonic 42" plasma (TH-42PX80U). It first started with the entire right half of the panel showing full solid white and black vertical lines. After about 5 minutes of this, the picture came back except for a 3" black vertical strip on the right end of the panel. It's been like that ever since.
I decided to open her up just to see if I could spot something. I discovered that the panel seems to be divided into 8 vertical strips which are connected to 2 PCB boards via ribbon cables (4 strips per PCB). I unplugged the ribbon cable near the problematic vertical black line and got this:
The black line was replaced with the white garbage shown in the picture. I unplugged the ribbon cable for another strip and got the exact same result. I'm not sure what to make of it. I assume it means that the panel itself is still functional since it can light up the pixels. I would guess that it's just not getting data from the cable. I don't know.
Anyway, that's about as far as I got. I don't know what else to try. I searched online for a while and couldn't find any useful information. I found the service manual for the TV, but was disappointed with the information that it contains.
If anyone has any suggestions, or has seen this problem before, I would be interesting in hearing about it.
