AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › PS3 wont play blu-ray
post #1 of 2
Hi, I have a Yamaha RX-V663 and a PS3 connected to my Panasonic G25. I have everything hooked up the right way and when i turn on my PS3 everything works fine; however, when i play a blu-ray the video wont show up. I can hear the sound of the menu but the video doesn't show up (once and a while it does). Im really confused because the PS3 works fine and i see the PS3 home screen but when i start the Blu-ray i see static then nothing then the image comes on the screen all distorted for a second..I used to have the same set up. the only thing different is the tv is newer. I have the PS3 hooked up to the Receiver then the Receiver hooked up to the tv. I have tried different Blu-rays and the same thing happens. also its the 1st gen PS3 and it does work when i plug it directly into the TV
I really need help, thanks
post #2 of 2
You need to post here: http://www.avsforum.com/avs-vb/showt...50544&page=982
and ask if anyone knows of any problems between 1st gen PS3 and the Yamaha RX-V663.
This thread is locked
