Update on the iSival projector. The problem I had with dark levels displaying a greenish color are now completely gone. I solved this by changing my computer HDMi settings pixel format. Selecting YCbCr 4:4:4 pixel format at 1280x720 resolution displays proper greyscale. About the low contrast, it is noticeable depending on the material being viewed. When it comes to video games it's not an issue at all really, things do look great, some games seem to leap off the screen, very vivid and detailed. On the other hand, real life based material such as movies, sports etc you can notice the less contrast but it highly depends on the content. I've watched HD baseball broadcasts and it was very enjoyable to watch. Peoples faces looked good, but on some other content peoples faces did look slightly washed out..this is more so on standard def material. Hi Def material the contrast does always look better, I'm not sure why that is..Most movies in Hi Def are very good..I'm pretty happy with this purchase to be honest because of the bang for the buck. I play a lot of video games, normally racking up many hours on my displays. I have left the projector on for over 8 hours at a time and even 12 hours in one day with one hour break in between..If you are a GAMER..I recommend it you will fall in love with it at 80 inches..If you're mainly into movies etc you might wan't a bulb based projector since you get higher contrast and you will not be putting as many hours into it most likely so the bulb will last you long anyways..I did the math.. according to the way I use my projector I would need a bulb once a year or more almost guaranteed based on my heavy usage and that's not factoring in early bulb failure and the bulb going dim..Too expensive for me..not an option. Like I said I use it a lot (typing this right now for expample), I do however wish these companies would bring out true 1080p LED with high contrast soon.
Also side note the other day I somehow fell asleep with projector on..the pc turned off all connected displays automatically and projector displayed static image (no signal found) all night long untill I woke up and turned it off. I was upset I had let this happen..I inspected the image very carefully looking at individual pixels..no image burn-in problem at all..This worried me since I know LCD technology can have some sort of image retention (LCOS is in some ways similar to LCD and DLP) I will hopefully not let this happen ever again, but it's good to know LCOS (liquid crystal on silicon) is good tech for computer use.
