Stevetd - Hopefully you have your Zappiti info in the same share as your media as the Dune can only open one share at a time.
My structure is:
Media (User Share)
Movies TV Shows Zappiti
_Zappiti Zappiti_Resources
edit: It seems to be messing up my diagram above for some reason. If you assume the Movies, TV Shows and Zappiti correspond to the dashes above them and assume the two Zappitis are underneath the Zappiti, it should make some sense.
To get the Zappiti icon on the home screen, you'll need to navigate to the _Zappiti folder via the network browser and hit the menu button and click add to home screen. This will put the Zappiti icon on the home screen.
I'm not sure if you tried this or where your problem lies but once you get it running, it is incredibly easy to continue to use. I had a hard time as I'm a total noob when it comes to everything computers but with a little reading, I was able to build a server, rip my movie collection and get two Dunes up and running with Zappiti. Another good thing about the Dunes and Zappiti is that the wife can work it pretty well.
It sounds like you already got the system storage set up so you shouldn't have to do the initiate system storage step again. It would be easier to help you if you let us know exactly where the process is breaking down.
My structure is:
Media (User Share)
