Originally Posted by
Mamasboy
It looks like I could exceed the 2 TB limit of the internal drive in my Dune Max fairly soon.
I was going to build an unraid server but want to hold off for now. If I plug in an external 2TB eSata drive into the Dune Max, does it just add to total storage or will I need to manage two drives on the Dune?
I am using Zapitti and would like to continue to have it manage everything on the Dune.
You'll have 2 drives, but that should be invisible using Zapitti. Just add the new movies location, you'll have two locations configured in Zapitti now. When Zapitti starts, it'll scan both locations. Using the Zapitti interface on the Dune, you won't see anything different than you see now. When you select on a movie the Dune will go to the correct HDD, all transparent to the user.
All that said, when you're transferring movies to your Dune from your PC, you'll have to choose which HDD to transfer too. Not a big deal. You can just fill one and then start on the next, or fill 'em evenly. I have 4 drives in a USB enclosure (Mediasonic); I label them A_G, H_M, N_S, T_Z. "Get Smart" goes in A_Z, "X-Men" goes in T_Z, etc. Doesn't really matter though. I've got about 100 blurays loaded and the drives are not quite a third full.
