Originally Posted by
drew.c
I have that exact PNY card but mine is 16GB Class 10. I cannot format it on the Dune using Sources, Memory Card. I tried NTFS and EXT3. I can format it on my PC with no problem. On the Dune it says Formatting Disk and it never finishes. The Elapsed time was up to 9 minutes. I cancelled it. I can read/write to it all day on my PC. My Dune Max does not like Class 10 cards.
I have a Smart B1 but I would think that the Max should handle sys memory the same way. It has been quite a while but as I recall I did not have any luck formatting my card with the PC either. I ended up deleting the partitions with the PC. Starting with a completely clean SD card, I used one of the DSFs to do the work on the Dune. You insert the clean SD, put the DSF on a USB memory stick (or HDD). You execute the DSF from the USB and it does the work. The description below was copied from the Dune Wiki that I linked in the earlier post.
- Dune_service_af_make_sstorage_and_ext3_on_sdc.dsf
Searches for a blank SD flash memory cards (without partitions or with a blank partition) size more than 2GB, and it creates two aligned sections, the first 2GB, second - for the rest of place. The first section is installed as a system drive. The second section is formatted in EXT3 with the standard cluster size.
The DSF described above is contained in this zip
http://nmt200.ru/wp-content/uploads/...ne_ext_dsf.zip
Good luck,
Charlie
