AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › New Dune HD Max and HD Smart anticipation thread Q3 2010
New Dune HD Max and HD Smart anticipation thread Q3 2010 - Page 256
post #7651 of 10092
[quote=dropzone7;21787649][quote=Litlgi74;21787600]I love yaDIS... and hopefully will never have to go back to Zappiti.
I have yet to find a place to actually download the Yadis software that works. The few times I tried it crashed my computer and or the instructions were in French. Can you point me in the direction of a link? The last time I tried was from MPC Club website.
Sure... here you go... http://www.mediafire.com/?6i66avohuqw3dmw
You will need the newest FW for your dune player for the software to work correctly.
yaDIS FAQ: http://www.mpcclub.com/forum/showthread.php?t=25906
yaDIS 2 Discussion thread (and location of newest software release): http://www.mpcclub.com/forum/showthread.php?t=25899
post #7652 of 10092
Originally Posted by Litlgi74 View Post
Here is the "All Movies" selection:
Very pretty, but it seems to have the same brain-damaged sorting as MyMovies. ("A Beautiful Mind" should sort under B, not A.)
post #7653 of 10092
I understand what your are saying... but doesn't the article "A" technically come before "B"?
post #7654 of 10092
[quote=Litlgi74;21787678][quote=dropzone7;21787649]
Thanks! I'm running the newest Beta. Should I be using the latest stable instead? I guess I should mention I'm using a Base 3.0 model as well.
post #7655 of 10092
[quote=dropzone7;21787808][quote=Litlgi74;21787678]
I am also using the Base 3.0... running the newest beta:120202_1544
post #7656 of 10092
[quote=Litlgi74;21787839][quote=dropzone7;21787808]
Cool, sounds like a weekend project perhaps. By the way, I love your signature. I miss that show.
post #7657 of 10092
Not a problem : yadis is able to use a sorting title, not like mymovies it can remove automatically a, the,...if you want or you can set the sorting title manually.
post #7658 of 10092
I too was using only BD ISOs... but realized that BD Folder structure was and is the way to go if you want programs like Zappiti and yaDIS to read resolution, framerate, audio codec, HD audio type, aspect ratio, video codec, and disc type.
The same data will have to be manually entered if ISO format is used with these programs
but strangely enough Zappiti and yaDIS can both read the tech data of DVD ISOs... but not BD ISOs.
I highly recommend yaDIS!
The problem isn't from yadis or zappiti, it's Mediainfo which is not able to read from BR iso...
post #7659 of 10092
Any huge differnce/benefit with this release VS 2.1.9 ^^^
Thxs!
post #7660 of 10092
for those interested in converting BD ISOs to BD Folders.... Easily!
I found this to work quite well.
Download winRAR : http://www.win-rar.com/download.html
Open WinRAR and navigate to your movie folder:
Select all movie folders and Extract to the specified folder:
Select the following options and in the "General" and "Advanced" tabs and click OK:
post #7661 of 10092
[quote=met64;21787990][quote=Litlgi74;21787678]
Thxs!
That I wouldn't know... I just started using at VS 2.2.
post #7662 of 10092
NEAT! Going to give that a whirl on some iso's!
post #7663 of 10092
Yadis offers you complete control over how you want your movies to be listed alphabetically (regardless of the movie file name on your hard drive.)
EDIT: I see Mr Eric beat me to it
post #7664 of 10092
Thxs!
Multiple selections and multiple shortcuts for both selections and genres. Very usefull
post #7665 of 10092
[quote=Mr Eric;21788176][quote=met64;21787990]
Great, Thxs.... Do you recommend uninstalling old version first?
post #7666 of 10092
Not needed, just install the new one over the old one.
post #7667 of 10092
I have only two problems with yaDIS... and one is my doing.
1. No way to get accurate audio codec mediainfo for TV Shows in BD.ISO or BD Folder Structure.
2. No Custom Posters or Fanart for Movie Sagas: But I found a work around for this: http://www.mpcclub.com/forum/showpos...68&postcount=4 but I am confident that this will be fixed in an upcoming release.
My feature request would be that we could search our catalogs by MPAA rating as opposed to TMDB ratings.
post #7668 of 10092
I love yaDIS too, the D1 is worth every euro just because of yadis. And yes, there is an option of ignoring the articles when sorting
post #7669 of 10092
1. As I said, this is a known problem with Mediainfo.dll, nothing to do with yadis unfortunately.
2. Yes it's planned in the next version (but Fred is very busy at this moment and we don't know when he start to work on it)
post #7670 of 10092
is it me or does yadis not have a way to show you new movies...
every other jukebox has a view where I can see the latest movies I added to my library sorted on modified date or date added to library.
the new movies section on YADIS shows me the last 30 days of movies (all of them in alphabetical order).
How does one get yadis to show sort movies by date added to library or preferable modification date/time of the movie itself?
There are tons of other programs. Coming from Ember media manager YADIS is like 5+ years behind in features. All the tools for Dune seem to be behind PCH tools which are behind XBMC and MCE tools. Ember even has way more features than MyMovies which seems to be the richest of the dune solutions.
I like YADIS but like MyMOvies more. Just not sure I want to spend $100 on it.
post #7671 of 10092
Zappiti had this feature as well... did you try adjusting the amount of days in the recently added section?
post #7672 of 10092
I look forward to the MPAA search option... but as far as not Mediainfo not being able to read the tech data of TV shows... I understand that it can't read the data of BD.ISOs... but it can for BD Folders. It appears that yaDIS doesn't allow BD Folders for individual TV Show Episodes.. Am I correct or did I miss something?
Thanks for the updates and info?
post #7673 of 10092
In yaDIS one of the search options is "recently added" indeed. What I cannot tell you is how long is "recent" for yaDIS as my Dune is 10 days old so I see all movies under recently added
post #7674 of 10092
If you scroll down a bit after this , you will also be able to chose if you want your recently added movies to be sorted alphabetically or by date
post #7675 of 10092
Scroll down past what? some details would be very much appreciated.
EDIT: Duh, I looked in Yadis and totally missed the scrollbar on the config dialog.
thank you thank you
post #7676 of 10092
thank you thank you
Glad you found it... I to missed the scroll bar for a while!
post #7677 of 10092
I'm running the previous stable firmware because of the bitstreaming feature, but I'd like to try yadis. Why was it mentioned that you need the latest firmware for it to run correctly?
post #7678 of 10092
What am I missing here? Don't all firmwares allow for bitstreaming?
post #7679 of 10092
bit streaming is working fine for me on the current production firmware. Have even watched two 7.1 movies one TrueHD and One DTS-MA.
Yadis is running fine too....
maybe they are talking about this decoding to PCM feature removal issue?
post #7680 of 10092
Yadis is using virtual items that were introduced in firmware 110923. You will need a firmware after this one to use it.
Re. "bitstream problems" I'm not aware about any or may be like Sean said, you're speaking about the PCM downmix problems...
