My harmony has discrete codes for power on/off. Try to find "dune smart" in the same media centre pc -> HDI section
Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.0 Format settings, CABAC : No Format settings, ReFrames : 2 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 1mn 45s Bit rate : 16.1 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 59.940 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Bits/(Pixel*Frame) : 0.129 Stream size : 203 MiB (99%) Language : English Encoded date : UTC 2010-12-25 18:14:42 Tagged date : UTC 2010-12-25 18:14:42 Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 1mn 45s Source duration : 1mn 45s Bit rate mode : Variable Nominal bit rate : 128 Kbps Maximum bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Source stream size : 1.61 MiB Language : English Encoded date : UTC 2010-12-25 18:14:42 Tagged date : UTC 2010-12-25 18:14:42
