Originally Posted by
drew.c
I had a strange problem on my Dune the other day. I have used Zappiti in the past and wanted to try yaDIS. After scraping, yaDIS looked fine on my PC but was leaving a few empty spaces on my Dune where the movie icon picture should have been. I later added a new movie to my collection and noticed now Zappiti was doing the same thing, leaving an empty space for the icon with no picture. I could hightlight the blank icon and press Enter and the new movie woud play fine. I keep my Zappiti and yaDIS on my 8GB SD card in my Dune. It is partitoned as 4GB NTFS and 4GB System Storage. I like using the SD card because it is in the front of my unit which makes it easy to access and totally hidden when inserted. Anyway, I finally figured out the problem. The 4GB SD partition was out of space. Both Zappiti and yaDIS never said anything about it being out of disk space while performing "Export to Dune". Zappiti was using 780MB so I assumed yaDIS would use approx. the same. Nope, yaDIS was using over 2GB for the same movies. Just thought I would pass this on.
Drew
some templates for yadis can use a lot of space for TV shows. Check in your dune interface the size of the aai file for an episode (/yadis/01/nameoftheshow/seasonnumber/01 for example). If the aai is 8MB, then you should change your template for another and save space.
FYI, if you're using one of my templates, i made an update a few weeks ago that will help you to save up to 60% space for every episode...
You can also switch to jpg backdrops instead of aai for your movies. For this just select the option in yadis set-up (in the interface tab)
