Originally Posted by
Jarod M
Question for those using My Movies Collection Management with external USB drives attached to their Dune D1 (not networked)-when doing the Path Configuration (attached drive), when prompted, what am I supposed to name the drive?
For example, one of my drives is the letter M: and has the volume label of 1Movies. When it is connected to the Dune, the Dune gives it a folder name of USB Storage 2. I have tried the names "1Movies" and "USB Storage 2," but but neither worked-when I click on the movie description in the My Movies folder on the Dune, the Dune replies "URL not found." I am using My Movies version 4.02, along with Dune firmware 110606-1315.
Take a look at the URL that MM is creating in your Dune index. Look under My Movies/.DuneTitles/1/Something/dune_folder.txt (something like that) for a line that starts with media_url= and paste one of those lines here.
It should look like:
Code:
media_url=storage_label://1Movies/something
If it doesn't you will need to change the Path Configuration in MMCM and rebuild the Dune index.
If that doesn't work you can edit (or create) a dune_folder.txt in the root of the USB drive to give it a better name. Put one line:
Then use the following for the Path Configuration:
