AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › New Dune HD Max and HD Smart anticipation thread Q3 2010
New Dune HD Max and HD Smart anticipation thread Q3 2010 - Page 288
post #8611 of 10800
Originally Posted by streamerlover View Post
Also flash storage is different than "system storage" ( which uses a flash drive) This has been a source of confusion for more than a few people...
Yeah, sounds like he might "think" he has system storage but in fact does not.
Dune BD Prime and Smart D1 still running strong, TV301 in the wings biggrin.gif
post #8612 of 10800
Yep! I am thinking he may have installed the flash drive but never went into the setup menu and told the dune to use it!
post #8613 of 10800
flash storage is indeed something different. Try to initialize system storage (in the dune's set-up/advanced menu if i'm correct). If your internal USB flash drive is empty it will be detected and will be transformed into system storage. once done this flash drive won't appear anymore and will be used for optional things, one being to handle correctly java interactivity for BR (which might be your problem if you don't have system storage...)
post #8614 of 10800
Yep! What he said!
post #8615 of 10800
Is there a recommended size for the USB drive to be used as system storage? I can't remember what's in there but will find out soon enough.
post #8616 of 10800
Minimum 2gb. I used an 8 in one and a 4 in another because that is what I had laying around..
post #8617 of 10800
@Damian,
How do you recommend ripping tv shows that have forced subs? I want no compression and I want lossless audio. Makemkv is great for those titles that don't have forced subs. I have Game of Thrones on Blu-Ray, but the Dothraki language needs forced subs...smile.gif I want to be able to rip it and have it be able to be cataloged by DFI or Yadis.
post #8618 of 10800
Originally Posted by RaggedEdge View Post
@Damian,
Well, all my TV shows I always compress, I have way too many and they would take up way too much space (in particular my Blu-ray TV Shows). So in that case I would burn in but obviously you don't want to go that route.
Really for mkvs you would just handle like a normal movie mkv, just make sure the subs are muxed in the mkv and are flagged as forced. However, the downside is that Dune does not recognize the forced subtitle flag, so you will need to keep subtitles on for the Dune and either also have the forced subs flagged as default, or toggle through manually
post #8619 of 10800
I can still use Makemkv to do all of this? I don't mind toggling the Dune and keeping subtitles on when watching certain shows.
post #8620 of 10800
Yes, I believe MakeMKV will look for forced subtitles and if present mux into the mkv (as well as flagging default). If you know an episode from Game that has forced subs I would try just on that episode and confirm everything works with MakeMKV/Dune before spending more time on.
Or I believe you could rip each episode to a folder rip (using Clown_BD) which would give you the standard forced subtitle support that you get for Blu-ray movies on the Dune (although this format isn't as widely supported amongst the various jukeboxes/players)
post #8621 of 10800
Yeah, that is the bummer. MKV is really such a great container for tv shows. Every jukebox works great with it.
post #8622 of 10800
. . . What is a buffer underrun anyway?
It means that the Dune did not read enough data fast enough from the file to satisfy the video/audio data-rate. The buffer acts between the file-access firmware-routines and the video/audio rendering firmware-routines. That error means that the buffer went empty, and there was no data to render.
post #8623 of 10800
I have never understood why Dune hasn't taken mkvs more seriously. If you recall, it took a while before chapter support was even added. Maybe this will change as you would expect the any new Dune players to come out will most likely not have full Blu-ray support
post #8624 of 10800
I love my Dune, don't get me wrong, but as a tv show watcher as opposed to a movie watcher, does a Popcorn Hour unit make more sense?
post #8625 of 10800
I have a ton of tv shows that I watch (over 3,000 episodes) on my Dunes without issue. The PCH does support forced subtitles in mkvs (although I believe they can be buggy at time, not sure if fixed). I guess it really just depends on your needs. Do you always rip subtitles for all your movies/tv shows, or only if forced subtitles are present?
post #8626 of 10800
Well it turns out I had an 8gb stick inside the Dune. I went ahead and tried a different one but it made no difference. Reset to factory defaults as well. Still get IO errors and buffer under run with BD lite mode. Regular BD mode ends in IO error eventually.
post #8627 of 10800
Did you go to the set up menu and tell the Dune to use that USB stick as "system storage"?
Simply installing it in the slot does NOT make it available for system storage.
To this date I have yet to ever see the errors you are reporting...
post #8628 of 10800
I only rip subtitles when forced subtitles are present.
post #8629 of 10800
Yep, I did initialize the drive as system storage and it showed cofirmed on screen. Trust me, if it's going to happen it's going to happen to me. I'm going to take this specific title (Sucker Punch) and turn my BD-ISO into a movie only MKV to see what happens. After ripping a few MKV's over the last few days its much faster and so far the files are trouble free and start right up. I can only think of a few titles that I really care about having extras for anyway so why bother for the others. Movie only is fine with me as long as it plays correctly.
post #8630 of 10800
instead of ripping to iso, try to rip as bdvm folder. Bdvm works for both movie only and for full rips. I always rip to bdvm with DVDFab and never had any problem, whether it's only movie+sub+audio or 1:1 full rip.
post #8631 of 10800
Just got an alert on the D1 for a new firmware update.
Did the update, but didn't notice anything new...
post #8632 of 10800
Got a firmware version number? I see nothing new on the dune "firmware zone" web sight"..
post #8633 of 10800
OK, so just keep the subtitles on with your Dune and you are fine. The issue is for those people who have multiple subtitle tracks in mkvs
post #8634 of 10800
you can find the new firmware here : ftp://ftp.hd-players.com/Firmwares/DuneHD/120815_2150_beta/
newest one is 120815_2150 (2151 for 101 and 301)
apparently it's just an official release following the june betas. May be it will solve the DTS HD problems on 101/301 ?
post #8635 of 10800
No love for the 53D?!?! It has become the red-head-stepchild now.
post #8636 of 10800
Would be great if that bug was fixed considering it is still present in the other newer Sigma chips (i.e. PCH)
post #8637 of 10800
They discontinued that model, correct?
post #8638 of 10800
Yes, and so has the Base/Prime 3 but they get a new firmware.
post #8639 of 10800
Yay! Long live my Base 3.0! I just added a custom skin to it this weekend as well!
Glad to see they keep up with the older models as well..
post #8640 of 10800
Yeah, but the 3.0 is running the same chip as the SMART models whereas the Lite is not
