Originally Posted by
replayrob
But... a NAS can have disk failure tolerance that's not common in PC's.
A common NAS setup is four hard drives- three store actual data- the fourth drive is for parity. If any one drive fails- you simply replace it with a fresh drive and the array automatically rebuilds with all your data intact.
Most NAS's are headless too.. throw them in a closet- no monitor, mouse or keyboard needed- just WOL to start them or push the power button- elegant simplicity!
That's RAID5, which PCs can do too (and were long before consumer NAS became common)
PCs have also been able to run headless forever if you want... so neither's at all unique to a NAS... which makes sense since a NAS is just a limited-use PC really.
fcwilt
Not exactly.
No, exactly.
It's a processor, some storage, and an OS. Just the NAS is a much more limited one in all cases.
fcwilt
Why would I need to move them - I rip to the NAS.
Your NAS has an optical and software to rip movies?
Because if not, you're ripping them on the PC and moving them to the NAS. (even if it never touches the PC drives on the way)
fcwilt
Fire up all four of your players and see what happens.
I don't have any need for 4 players (if we're not counting the PC as a player) but even if I did it wouldn't make any difference... the PC certainly has a lot more powerful hardware than the NAS does (unless it's a lot more expensive than a consumer level NAS- but if that's the case I get to compare it to a much more expensive than consumer level PC).
A NAS isn't magic. It's a very limited-feature file server... versus a PC which is a broad-featured file server.
(granted, if you're comparing a nice NAS to some dude who hooks a cheap USB drive to a generic windows emachine PC, the NAS will look pretty good... but compare to a properly configured PC with RAIDed drives attached via a fast interface and that's a whole other story)
Edited by Kurtz9 - 9/10/12 at 9:27am
