Originally Posted by
dbone1026
How did you create a FLAC MKV with MakeMKV, I don't recall ever seeing that option ?
I tested FLAC + mkv on my Dunes and they work fine ( I created with either ANother eac3toGUI or Clown_BD + MKVMerge)
Preferences ==> General tab ==> Check the expert mode.
Close MakeMKV and re-open. Click on preferences again and you will a new tab called Advanced. From there you could select a different profile.
Here's a link for a profile that will covert to FLAC.
http://www.makemkv.com/forum2/viewtopic.php?f=10&t=5749
By the way, here is the Media info for the MKV+FLAC that did not work in my Dune.
General
Unique ID : 96615953232129960103738954961631689121 (0x48AF8E453533EF370A46F6E92B4DB9A1)
Complete name : Y:\title00.mkv
Format : Matroska
Format version : Version 2
File size : 24.0 GiB
Duration : 2h 30mn
Overall bit rate mode : Variable
Overall bit rate : 22.8 Mbps
Encoded date : UTC 2012-12-16 07:00:41
Writing application : MakeMKV v1.7.9 win(x64-release)
Writing library : libmakemkv v1.7.9 (1.2.0/1.1.0) win(x64-release)
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Format settings, GOP : M=3, N=24
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 30mn
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Language : English
Default : No
Forced : No
Audio
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : A_FLAC
Duration : 2h 30mn
Bit rate mode : Variable
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Title : 3/2+1
Writing library : MakeMKV v1.7.9 win(x64-release)
Language : English
Default : Yes
Forced : No
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : English
Default : Yes
Forced : No
Text #2
Format : PGS
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 00
00:04:18.925 : en:Chapter 01
00:09:53.009 : en:Chapter 02
00:12:13.441 : en:Chapter 03
00:19:09.064 : en:Chapter 04
00:23:53.473 : en:Chapter 05
00:30:15.480 : en:Chapter 06
00:35:29.418 : en:Chapter 07
00:40:32.930 : en:Chapter 08
00:46:28.035 : en:Chapter 09
00:50:25.564 : en:Chapter 10
00:56:18.625 : en:Chapter 11
00:59:52.380 : en:Chapter 12
01:05:45.191 : en:Chapter 13
01:11:55.853 : en:Chapter 14
01:17:04.327 : en:Chapter 15
01:22:10.258 : en:Chapter 16
01:30:36.639 : en:Chapter 17
01:34:38.172 : en:Chapter 18
01:39:21.830 : en:Chapter 19
01:44:52.410 : en:Chapter 20
01:49:14.714 : en:Chapter 21
01:54:55.805 : en:Chapter 22
01:59:36.043 : en:Chapter 23
02:04:59.908 : en:Chapter 24
02:10:27.194 : en:Chapter 25
02:16:20.630 : en:Chapter 26
02:21:04.789 : en:Chapter 27
