Originally Posted by Jon Spackman
Yadis question for the experts:
Can you hide the first screen that makes you choose between movies and tv shows? If you have no tv shows flagged as tv shows will it auto-hide that screen?
I have a good friend who uses yadis (Ivan) but I don't like how his male you choose the movies from that almost blank screen first.
you can't change the main menu. You can change the appearance (font, size, position), but not remove TV series or Movies access.
If you want for example to start right away with teh movie wall, the easiest solution is to create a direct shortcut. Just navigate to the movie wall, then press popup menu and add the wall to the favorites. This will create a shortcut in the dune UI that will bring you directly to the wall (you can do this with any part of yadis you want).
If you think that the main menu is a bit empty and boring, you can use the Red Carpet template which makes it very nice : http://www.mpcclub.com/forum/showthread.php?t=28388&page=2
Edited by Mr Eric - 1/14/13 at 1:12am
