Originally Posted by
halfelite
Because real world says if they are planning a Q2 or even early Q3 release they have not even start testing press boards unless they are going to use off the shelf boards that they dont need custom made, If its a custom board they would have to know final product specs around this time in order to get one sent off and made and back in for testing. Then on top of that. If they switch chips come June who is to say everything they tried on a different model would still be good.
No one is saying they will suddenly switch chips last minute. The point was simply that the Berryville chip that has been rumored may or may not be the chip. They may already have custom boards that they are testing, they may be working closely with Intel, I unfortunately can't say for sure. At the end of the day I am sure they will go with the chip they feel gives them the best player
halfelite
And the xbmc comment, was about this "It is NOT an HTPC. XBMC is simply being used as purely the front end, there will be a separate playback engine that will handle playback of all file types (so disregard anything you know about how XBMC handles file playback)" That is exactly how xbmc does handle video, If you set xbmc to use an external player it will use whatever you want it to use be it vlc or MPC-HC w/ MadVR. Still does not take away the fact its an htpc. They are pushing very hard that its not an htpc not sure if it was your wording or theres. Same with the Disc playback tell xbmc to play disc in power dvd you have cinavia driven disc playback. And while some could say because its running a SoC its not an htpc its still based off a non SoC cpu.
Yes and no. Most people equate an HTPC with the ability to install your own O/S, software, etc... For example, look at the Xtreamer Ultra, which runs XBMC as an install, but you can run a dual boot Windows O/S, etc... that is what I am talking about specifically in regards to an HTPC, and I think that is what most people think of (which when the discussions first started about this player as expected people started talking about what else they could install, etc...).
Secondly, you mention MPC, MadVR, etc... which yes in that respect that is external playback. However, and once again imo what I consider an HTPC, the user will not need to do any of that stuff. They will not need to install and configure MadVR, MPC, make sure they are using the right filters for video or audio codecs, etc...
It is meant to be a plug n play player, just like a Dune, PCH, etc...
