AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › New Dune HD Max and HD Smart anticipation thread Q3 2010
New Dune HD Max and HD Smart anticipation thread Q3 2010 - Page 320
post #9571 of 10108
Originally Posted by syk69 View Post
Awesome thanks!
Also in the review of the 303D, you mention a patch to decode DTS-HD MA to multi channel PCM. I believe this patch decodes the DTS core and so you don't get HD audio multichannel PCM. Major bummer for those without receivers that decode HD audio. At least according to this post from another forum...
http://www.avforums.com/forums/18482238-post559.html
Correct, it grabs the DTS core track (this is actually common for these players, I believe there would be a separate licensing fee in order to decode the actual DTS(MA) track). For a TrueHD Blu-ray it is decoding/passing thru the embedded AC3 track and not decoding the actual TrueHD track (once again, no license which can be seen in the inability to downmix a TrueHD mkv). My guess, the focus is simply only folks who use HDMI and have a receiver that can handle the decoding itself.
post #9572 of 10108
Guys nobody is talking about the 2d subtitles (instead of 3d) showing up on 3D content. I know this is an English forum and subtitles may not be of great importance but this is a super major bug. Dune if you are reading please fix it! It is unacceptable! And everyone else saying 3d subtitles are fine please stop saying that because you probably don't know how 3d subtitles look like.
post #9573 of 10108
Do you know by any chance if the new prime 3d with the Intel chipset will be able to decode the actual DTS-HD MA to multichannel PCM? I have a HDMI receiver that doesn't decode HD audio. But receives multichannel PCM over HDMI just fine.
post #9574 of 10108
What is the Prime 3D? Do you mean the Max 3D (I assume so since you mention Intel).. Honestly no idea, and no reason to speculate at this point. I would hope it would given it will be close to a $700 player.
post #9575 of 10108
Sorry got the names tangled. Yes I meant the Max 3d with the Intel chipset and XBMC frontend. I hope so too!
post #9576 of 10108
Originally Posted by lazarus18 View Post
I did that and after awhile same hdd is lost. So, it is related to the particular hdd.
It is still very odd because the two drives are the same model. Maybe this one is defective somehow.
No luck. After I have removed the disappearing HDD the other one started to disappear.
I wonder if this can help - wdidle3.exe to reset idle time. I have read similar problems with PCH and Green drives.
post #9577 of 10108
Question for you Dune owners, anyone know if you can output dual simultaneous audio signals? Someone has asked me, he wants to be able to send audio out via HDMI to his AVR and at the same time send out audio via analog to a pair of headphones.
post #9578 of 10108
i believe so. pretty sure i tested that once and found that all audio outputs are active simultaneously. i know for a fact that at the very least the digital coax/optical and analogs are active at the same time. thats how i have the dune that distributes through my whole house system set up - analog and digital both go to the matrix, rooms with receivers the get the digital audio, rooms without get analog.
EDIT: found an old post of mine which seems to confirm exactly what you want: http://www.avsforum.com/t/1270503/new-dune-hd-max-and-hd-smart-anticipation-thread-q3-2010/2490#post_19864480
Edited by absolootbs - 2/12/13 at 9:59am
post #9579 of 10108
Much appreciated, I have passed along the info
post #9580 of 10108
Which dune player that is still available can play bd iso with menu? ( not bd lite)
post #9581 of 10108
Hi Mac,
As far as I can tell, the Dune HD Max and all three in the DUNE HD Smart series are still available. As opposed to the TV series, they have full Blu-Ray menus as well as BD-lite.
post #9582 of 10108
Zappiti adds music
I am surprised there is not a dedicated Zappiti thread . . .
A new version of Zappiti is out, and it is beginning to include support for a music library. The video half of Zappiti seems unchanged.
It looks like it could be quite good, once it is complete. It is more functional than the movie portion, in that you can select by artist, album and genre. For movies, you only have genre.
It scraped my library, about 3600 files, in about an hour. I have no idea from where it got the artwork, but it looks quite good. One issue is that it misidentified about a quarter of my library, although all of my metadata was correct. That in itself would not be a problem, except that there is not yet any mechanism to correct it, like there is with movies and TV shows.
Outside of being able to define a share as containing "music" in addition to the previous "movies" and "TV shows", there appears to be no changes in the Zappiti configuration menus to support music. Also, when I exported to the Dune, none of the music information was exported. So it's clear it is not yet complete.
I don't expect Zappiti can do anything about the Dune's gapless-playback deficiency, so I still might not use the Dune for music, even once they do get it finished.
post #9583 of 10108
Originally Posted by MarkHotchkiss View Post
Zappiti adds music
I thought I read that Zapp music is reserved for HTPCs and their Zapp player (maybe that is why none of the music information was exported)?
post #9584 of 10108
zapp music is indeed reserved to zapp player and HTPC. FYI : if you have at least 1 zapp player and 1 or more dune, you can use the music part on all the dunes (zapp player or not).
post #9585 of 10108
Oh, Ok. It's not that bad, as I don't use the Dune for music. I hope this means that the Zappiti player can do gapless audio.
But it is a nice interface, so I may try it on my wife's PC, which she uses to listen to music while she works.
post #9586 of 10108
After reading Damien's review of the 303D I decided to order one. For a long time I've being using a Atv2 with xbmc but it simply doesn't have the horse power to deal with interlaced mpeg2 and 1080p MKVs. My Sony BDP isn't too bad but there are too many workarounds and trade offs so a dedicated streamer seemed like the logical next step.
Hope the DTS MA Dropout issue gets fixed in the next firmware update, otherwise ill try something like the MED600.
Btw, in terms of networks I can go DLNA, Samba or NFS. Do you guys prefer or recommend NFS in terms of performance or doesn't matter ?
post #9587 of 10108
If you are not trying to watch 3D movies then SMB should work just fine. NFS seems to be needed for 3D movies.
post #9588 of 10108
All,
Do we know a way to ADD Pandora on my DUNE SMART D1
post #9589 of 10108
no (at least for now)
post #9590 of 10108
No, NFS is not needed for Blu-ray 3D with the Dunes (for the Mede8er it is)
post #9591 of 10108
Awesome. I thought NFS was the rule for playing 3D.
post #9592 of 10108
not needed on dune, SMB on base 3D tops 25MBs (i think that Damian did the test) which is more than enough compared to the max 80/90Mbs needed to play 3D files.
post #9593 of 10108
Guys, what is the main negative to ripping Blu-Rays to lossless MKVs? Is it the forced subtitles? I'm currently ripping to folder structure, but I'm wondering if just ripping to mkv isn't easier.
post #9594 of 10108
Probably forced subs (but then again not all players support proper forced subs in BR folders either, i.e. any BD Lite player). I think back in the day mkv support was hit or miss, but seems like in general it has gotten much better, so I think you are fine either way (and going with an mkv resolved seamless branch issues). Other issue with mkv, if you have a TrueHD Blu-ray and keep in in a BR Structure (or m2ts/ts) you can keep both the TrueHD and embedded AC3 track. With an mkv you cannot do this, so you get just the TrueHD track ( a problem if your player does not decode TrueHD and you are not doing pass thru)
post #9595 of 10108
I thought there was a patch created for the Dune players so the Force subs would work?
post #9596 of 10108
Yes, but sometimes getting forced subs into the mkv can be problematic (it isn't always clear what the forced subs are for some movies/discs when ripping to mkv, that is what I meant).
post #9597 of 10108
I see. I just ripped a movie with MKV, and on the selection boxes for the subs several of them said "forced." I had to use MKV rather than ClownBD. I was trying to rip The Perfect Storm, and ClownBD final file would be 720p, but with MKV it would be 1080p. Weird.
post #9598 of 10108
My Zappiti came with a Music Player code.
post #9599 of 10108
Although I haven't done much in the way of ripping to MKV, I think some of the same concerns exist with blu-ray movie only rips. What I do is playback the original disc in TMT5 first, if the subtittles are off by default - generally speaking if there are forced subs they will be located in the first English subtitle track. On the other hand, if one of the English subtitle tracks if checked its not a forced subtitle track per say but you have to designate that track as such so that it plays back. when needed (I accomplish this through DVDFab by putting a checkmark next to it so it is turned on my default in my BD movie-only ISOs).
I would imagine a similar strategy would yield similar results for MKVs.
By the way dbone, I know you're the resident ripping expert so what is your preferred ripping method for 3D blu-rays bearing in mind the limitations of the new players with regards to forced subtitles and seamless branching?
I just bought two extra D1s to put in storage (in case one or both of my Prime 3.0 or HD Max ever fail) but if a decent solution for BD ISO exists I would consider working that into my rack.
For that matter, I would consider anything that is capable of playing back the 3D BD properly in any format that doesn't require some sort of compression so I guess I'm wondering if any player is there yet or if I'm best to stick with my exisitng Dune players for now and using MKV SBS or blu-ray SBS (though that format can't seem to produce 3D compatible subtitles)?
post #9600 of 10108
Yes, the same process can be done for mkv, I was looking more at the easiest way to get from point A to point B since i know some people will not want to go through the additional steps of forced subtitle verification, etc...
I just picked up a B1. I gave my D1 to my Dad (and will take that back as my backup if need be) and still have my BD Prime running as well.
As far a 3D BD, honestly all options suck right now lol. I don't feel too great about seamless branch or forced subtitles being corrected in BD Lite. To me, that leaves mvc mkvs which take care of both seamless branch and forced subtitles (as long as the player supports forced subs in mkvs). Problem is right now mvc mkv support is very scarce (only Realtek 1186 chips, but those don't have forced subtitle support). Hopefully though you will start to see more players support mvc mkvs, and unless someone comes up with a way to fix forced subs and seamless branch in Blu-ray playback, then mvc mkv seems like the best option. Of course the advertised new Dune Max is supposed to have full BD support, but at the probable price tag ($700+) it is most likely not a viable option for many
