Netgear NeoTV 550 - Page 49
post #1441 of 6184
Originally Posted by overburn dk View Post
Yes, I have tried to rename a movie file from .ts to .m2ts - and it playes ok by VLC-player but not on NTV550.
I hope this is a firmware issue, right ?
Probably not. The eva9150 does not support standalone .ts files, you have to have the corresponding .ifo file.
You can however rename your .ts files to .mpg files and they should play fine on the Neo.
Gear mentioned in this thread:
post #1442 of 6184
I have tried to rename a .ts to .mpg and you know, It does not play,
Not on my VLC-player and not on my NTV550. My NTV dont se .mpg
When i record a movie on my VU+ duo the files is not only a .ts file
A movie is recorded as 6 files:
*.ts
*.eit
*.ts.ap
*.ts.cuts
*.ts.meta
*.ts.sc
When I play the files I can select sound and subtitles.
post #1443 of 6184
*.ts
*.eit
*.ts.ap
*.ts.cuts
*.ts.meta
*.ts.sc
On the Neo try going into Video|Folders and browsing to the location where the particular .mpg file is stored. Is it still not visible?
post #1444 of 6184
Ok, I have played around with the 550 for a couple of hours.
I like it the experience overall.
I need one more day to do some test of the files before I'll write more about playback.
There are some bugs with bd-iso/m2ts not displaying the whole picture. You can see only 1/10 of it and subtitles. I think this is a overlay issue because I have been able to get the whole picture back one time when switching in and out of the menues.
I tried 200 mkvsamples so far and most of them seem to work. Had black level problems with some so i need to check these on my computers aswell.
Menus
Cant use the remote A-Z with drop down boxes, eg selecting Sweden in Country (need to scroll instead or use +pg-).
Can't use 24h... only AM/PM
Weather report seems to be acurate.
Internet Apps
Youtube Video
* Very fast loading and image quality is ok (can see alot of DNR and banding/grading sometimes)
* Time scrolling is easy and works!
* Alot of alternatives eg categories/search/most viewed. (Cheerleading channel )
* Adding a video to your playlist works, but it took me a couple of minutes to figure out how to go directly to the next stream in the playlist. (popup menu-> press down->press right)
* If you want to change to another stream while still watching something, you first need to stop the current one or use the solution above. (this is really stupid and must be changed. The user should get an option if he wants to add it to the playlist or go directly to the new stream instead imo)
* Avatar 1080p flash trailer (1920x1080 14.1Mbps, AAC 44.1Khz 2.0) worked without problem!
* Playlist automatically clears itself when everthing has been seen.
RadioTime
*The player hanges when selecting local radio channel (Bandit Rock 106.3). Needed to pull the plug.
Could repeat the crash by trying to select a couple of random stations again.
(player wanted me to send a crash report to Netgear)
RadioIO/Shoutcast
* Really good and fast. Didn't notice the same bug as above with this function.
Flickr
* Can't find myself on flickr, but found a friend. This must be some kind of settings with flickr preventing it from finding mine I guess
* Can't find my taged pics. But i found someone else who had tagged my pic somewhere
*Seems like you cant open a pic in someones stream and press next to see the next pic.
*Quality isn't very good
*Overall flickr-function needs alot of improvment!
News channels
Seems to work like it should. I can watch most if it... but not ABC News (maybe GeoIP)
Other stuff
*I had to restart the player a couple of times by pulling the plug. Usually when I change videos while already playing something or when watching something and suddenly the video stops. It doesnt help to soft reboot.
I can replicate this bug with one MKV with DTS-HD track!
* Back of the remote looks like bad suede after a while. The surface likes fingerprints.
*If you press back in a movie/youtube or whatever you will be taken to the menu and the video is still playing in the corner. The logical thing would be to press back to go back again, but instead they have choosen the menu button as the return button for this. The back button always goes back until you get to main menu.
*Sometimes when you use the search function in eg Flickr, CAPS is always activated. Guys coding these things apperently thinks every one always has the first letter with capital letters but forgot to make it auto off after pressing the first key.
*The stupid popup menu sometimes gets in the way making it impossible to click ok when browsing menus.
Eg if you are playing radio in the background and have the popup menu on. You have to manually deactivate it by pressing "Popup menu", but the back button is always working. This should/could be solved by an option to make the popup menu disapear after eg 10 sec.
*I miss a delete key on the remote when typing letters. Oh wait its the back button 5 cm away from the rest of the letters! <- Stupid!
* Miss that I cant put the cursor where I want when typing. I need to clear everything and write it again if i make a misstake
post #1445 of 6184
fine fine
can anyone of the owner report, if its possible to stream via WIFI or LAN 720p and 1080p. Is it enough bandwith to stream mkv files?
does the NTV 550 play mkv, with the new header compression? o!Play needs to disable compression with mkv merge.
how good is the firmware support from Netgear? Anyone had a netgear multimediaplayer before?
I was not so happy with the Asus support, because they nee 2-3 Month to fix only 1 problem. It was to long.
post #1446 of 6184
One more thing before I go to bed.
Almost every 16:9 (or close to 1:78:1) mkv I have tried is not displayed correctly. I usually have to zoom in (-) the pic by 3 clicks.
Is there really no overscan settings?
edit: it's present in bd-iso also.
post #1447 of 6184
Thanks for your report Bozzeta. Do you think you'll keep it or send it back?
Can't you use the arrow buttons to move back and forwards along the text rather than deleting everything?
post #1448 of 6184
Is that with the Aspect Ratio set to Auto?
During playback there is the pop-up menu with the "Fill screen" option. Does that solve the problem?
post #1449 of 6184
I'll keep it for 30 days and see if the Netgear techs work as much as the Boxee people =)
But most of the problems could be fixed with fw I guess.
Nope that didn't solve it. None of the options does any difference on my TV.
Not changing resolution to 720p either.
One more interesting thing! I switch to NTSC and the box freaked out... I can no longer change aspect ratio to fill screen!
post #1450 of 6184
Can some of you beta testers comment on my problems?
post #1451 of 6184
or comment on my questions a few posts above?
post #1452 of 6184
I dont have my netgear wifi adapter here right now. Later in the week.
fill screen is not available now at all.
Found another bug. If you zoom in/out of the pic, you cant select 16:9 or 4:3to restore the picture. You need to start and stop the movie.
post #1453 of 6184
Hello
Bozzeta, what FW version are you on?
I think I read a few pages back that the latest Beta version is in the 3.0.26x range.
The latest released FW version on Netgear Website is 3.0.234.
Since the official release of the NeoTV 550 is not supposed to be until early December (from what has been said on this Forum by Bob Silver and others) then I would assume that many of the Bugs you are experiencing will be fixed by then.
According to Scan in the UK they will receive stock on 14 December and my unit will be with me on December 15.
Kevin
post #1454 of 6184
Yes its 3.0.234
Official release has already begun. I mean if they do not consider Europe as a market then we have a problem.
Elgiganten is the largest retailer in Scandinavia. It's not like they stole a shipment from Netgear.
They really need to get a new fw out if they have fixed all of these problems already.
post #1455 of 6184
About ratio issues, i never faced that with my br-iso. Neither with mkv but i don't have a lot.
So...strange. What firm do you have ?
post #1456 of 6184
I have a lot of .mpg files and it's visible and it is playing fine on the NTV550.
I just can't rename a *.ts file to a *.mpg file - it wont play.
post #1457 of 6184
fine fine
This really has nothing to do with the NeoTV.
Wifi streaming for HD depends on the quality of the wireless signal you have. If you have a good signal 720p is easy and 1080p is possible but less likely. Regular ethernet is more than enough to do full BR ISO streaming.
post #1458 of 6184
Hello all
One for the Beta Testers.
Was there a new Beta FW yesterday?
Just curious
Kevin
post #1459 of 6184
ok, because i have Wifi with good signal and DLAN (Powerlan). The Netgear WIFI Addon for the NTV550 have the same Price as a 3. Powerplug for DLAN.
post #1460 of 6184
One more things before I forget.
You can't use the up/down with the timeseek button (like in PMS). You need to enter a number.
But you can move in time with the time slider also so its not a big problem.
post #1461 of 6184
.ts, .mpg are containers only. Check your codecs with mediainfo.
post #1462 of 6184
Originally Posted by kncowans View Post
Hello all
Just curious
Kevin
Actual firm is 265. No new firm this friday.
post #1463 of 6184
The Boxee Box has no problem playing .ts files. I tried a 1080i file last night.
post #1464 of 6184
FYI
The system log will have all your passwords displayed for your networks shares and so on. I don't know it this is the same log file that uploads to Netgear when the unit crashes but probably.
FW 3.0.101007.234.EU
Specs that might be interesting to someone:
<5>Linux version 2.6.22.19-27-t3bd (daldover@daldover-ubuntu) (gcc version 4.3.3 (Sourcery G++ Lite 4.3-154) ) #20 PREEMPT Thu Sep 30 21:02:43 PDT 2010
<4>Mixed DRAM usage enabled.
<4>Configured for SMP864x, detected SMP8642 (revision ES3).
<4>Detected CPU/System/DSP Frequencies: 661.50/330.75/330.75MHz
<6>SMP86xx Enabled Devices under Linux/XENV 0xcf79bcb0 = 0x000103f8
<6> Ethernet IR FIP I2CM I2CS SDIO USB SATA
<4>Desired kernel memory size: 0x08000000
<4>Max. DRAM0/1 size allowed: 0x08d00000/0x00004000
<4> Mapped 0x80000000(size 0x04000000) via remap2
<4> Mapped 0x84000000(size 0x04000000) via remap3
<4>Final kernel memory size: 0x08000000
<4>CPU revision is: 00019749
<4>FPU revision is: 01739300
<4>Determined physical RAM map:
<4> memory: 08000000 @ 04000000 (usable)
<4>Desired kernel memory size: 0x08d00000
<4> Mapped 0x88000000(size 0x00d00000) via remap4
<4>Final kernel memory size: 0x08d00000
<4>User-defined physical RAM map:
<4> memory: 08d00000 @ 04000000 (usable)
<6>Wasting 131072 bytes for tracking 4096 unused pages
<6>Initrd not found or empty - disabling initrd
<7>On node 0 totalpages: 13120
<7> DMA zone: 25 pages used for memmap
<7> DMA zone: 0 pages reserved
<7> DMA zone: 13095 pages, LIFO batch:3
<7> Normal zone: 0 pages used for memmap
<4>Built 1 zonelists. Total pages: 13095
<5>Kernel command line: console=ttyS0 mem=141M
<4>Primary instruction cache 32kB, 4-way, physically tagged, linesize 32 bytes.
<4>Primary data cache 32kB, 4-way, virtually tagged, no aliases, linesize 32 bytes
<6>Synthesized TLB refill handler (19 instructions).
<6>Synthesized TLB load handler fastpath (31 instructions).
<6>Synthesized TLB store handler fastpath (31 instructions).
<6>Synthesized TLB modify handler fastpath (30 instructions).
<4>PID hash table entries: 1024 (order: 10, 4096 bytes)
<4>Using 330.750 MHz high precision timer.
<4>Console: colour dummy device 80x25
<4>Dentry cache hash table entries: 32768 (order: 3, 131072 bytes)
<4>Inode-cache hash table entries: 16384 (order: 2, 65536 bytes)
<6>Memory: 133120k/144384k available (3124k kernel code, 11040k reserved, 699k data, 6096k init, 0k highmem)
<7>Calibrating delay loop... 330.13 BogoMIPS (lpj=1650688)
<4>Mount-cache hash table entries: 2048
<6>NET: Registered protocol family 16
<5>PCI: pci host support disabled
<5>SCSI subsystem initialized
<7>libata version 2.21 loaded.
<6>usbcore: registered new interface driver usbfs
<6>usbcore: registered new interface driver hub
<6>usbcore: registered new device driver usb
<6>NET: Registered protocol family 2
<6>Time: TANGOX clocksource has been installed.
<4>IP route cache hash table entries: 4096 (order: 0, 16384 bytes)
<4>TCP established hash table entries: 8192 (order: 2, 65536 bytes)
<4>TCP bind hash table entries: 8192 (order: 1, 32768 bytes)
<6>TCP: Hash tables configured (established 8192 bind 8192)
<6>TCP reno registered
<6>JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
<4>fuse init (API version 7.8)
<6>io scheduler noop registered
<6>io scheduler anticipatory registered (default)
<6>io scheduler deadline registered
<6>io scheduler cfq registered
<6>SMP86xx ir (254:0): driver loaded (wait_period = 100ms, buffer_size = 6)
<6>tango3dog: Hardware Watchdog Timer for SMP864x/SMP865x 0.1 (def. timeout: 30 sec)
<6>Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
<6>serial8250: ttyS0 at MMIO 0x0 (irq = 9) is a 16550A
<6>serial8250: ttyS1 at MMIO 0x0 (irq = 10) is a 16550A
<6>loop: module loaded
<3>tangox_enet0: detected phy at address 0x09
<6>tangox_enet0: Ethernet driver for SMP864x/SMP865x internal MAC core 0: 100Mbps Base at 0x26000
<6>tangox_enet0: mac address XXXXXXXXX
<5>tangox_enet1: ethernet mac_core 1 support is disabled from XENV
<4>k_name=Tangox SATA 0 driver=Tangox SATA 0
<4>SATA version 0x3139302a ID 0x0 is detected
<6>scsi0 : Tangox SATA 0
<6>ata1: SATA max UDMA/133 cmd 0xa0023000 ctl 0xa0023020 bmdma 0xcdcdcdcd irq 49
<6>ata1: SATA link down (SStatus 0 SControl 300)
<4>k_name=Tangox SATA 1 driver=Tangox SATA 1
<6>scsi1 : Tangox SATA 0
<6>ata2: SATA max UDMA/133 cmd 0xa0023800 ctl 0xa0023820 bmdma 0xcdcdcdcd irq 62
<6>ata2: SATA link down (SStatus 0 SControl 300)
<7>ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
<6>USB Universal Host Controller Interface driver v3.0
<6>Initializing USB Mass Storage driver...
<6>usbcore: registered new interface driver usb-storage
<6>USB Mass Storage support registered.
<6>sdhci: Secure Digital Host Controller Interface driver
<6>sdhci: Copyright(c) Pierre Ossman
<4>tangox_sdhci_drv_init in
<4>SDIO0 is enabled.
<4>tangox_probe: ......!!sdhci_tangox_probe_slot in
<4>sdhci_tangox_probe_slot: pad is set......!!SDHCI_CAPABILITIES 0x69ef30b0
<4>mmc0: Invalid maximum block size, assuming 512 bytes
<4>mmc->caps 0x0000000d mmc->max_blk_size 512
<4>mmc_add_host in
<4>mmc_start_host......
<4>mmc_start_host in
<4>mmc_rescan in .....
<4>mmc_start_host out
<4>mmc_add_host out
<6>mmc0: SDHCI controller on SDIO [sdhci0-tangox] using DMA
<4>tangox_sdhci_drv_init out
<6>TCP cubic registered
<6>NET: Registered protocol family 17
<4>mmc_send_app_op_cond
<6>Freeing unused kernel memory: 6096k freed
<4>cmd.resp[0] 0x00000000
<4>after mmc_attach_sd ocr 0x00000000
<4>after mmc_attach_mmc ocr 0x00000000
<4>mmc_rescan out .....
and so on
post #1465 of 6184
Dolby TrueHD: 7.1 lossless TrueHD audio - (30mbps-L4.1-TrueHD.m2ts) - It won't switch to TrueHD on my Onkyo 606 if I have played any other audio format before selecting a THD file. Solution: need to select stereo output, play the file again, it outputs PCM 7.1Go back and select passthrough, run the file again... now it works until I play some other format.
(I have a x264 rip of Grease with truehd and it plays however that one without this problem. But it has alot of compression artifacts with the video instead)
DTS-MA: 7.1 DTS-MA lossless audio - (28mbps-L4.1-DTS-MA.m2ts) - Plays but is identified as DTS-HD HR
M2TS: Standard 1080p M2TS ripped from a blu-ray - (8.3mbps-1080p-30fps-L4.1-3ref.m2ts) - Plays without problem
DVR-MS: Microsoft's old proprietary TV recording format (6mbps-480i-MPEG-ASF.dvr-ms) -Works - Display switch mode also
WMV9: 1080p WMV9 video with 5.1 WMA audio - (8mbps-1080p-24fps-WMV9-6chWMA.wmv) - Plays without problem
HDTV: 1080i 60hz HDTV rip - (10mbps-1080i-60fps-L5.1-8ref-HDTV.mkv) - STUTTERS frame by frame
AVCHD: 1080p M2TS from a Sony HD camcorder - (11.6mbps-1080p-AVCHD-Sony-Camcorder.m2ts) -Plays without problem (is the timestamp supposed to flash?
Improper encode: The infamous Planet Earth clip with an absurd 16 reframes. The bird scene stutters even on high end PCs - (19mbps-1080p-24fps-L5.1-16ref-improper.mkv) - Plays without problem (subtitles don't look good thou)
DTS: Standard DTS 5.1 audio - (10.2mbps-1080p-24fps-L4.1-5ref-DTS.mkv) -
MP4: Apple trailer with 9 reframes and AAC audio - (4377kbps-1080p-24fps-L5.0-9ref-AAC.mp4) - Plays but looks like black levels are wrong and I see alot of compression artifacts/banding
5.1 FLAC + SSA: Multichannel FLAC audio and SSA subs including complex styles and transitions - (L4.1-8ref-6ch-FLAC-SSAsubs.mkv) - Plays but has enourmos amounts of compression artifacts and no sound
OGG: 720p Ogg Theora video with Vorbis audio - (4.6mbps-720p-30fps-Theora.ogg) - Not displayed in browser
RMVB: Real Video variable bitrate Unknown if it is RM9 or RM10, as they both use the same header (RV40) - (SD-25fps-RV40.rmvb) - Not displayed in browser
TRP: 1080p Kaon DVB Transport Stream with dual AC3 audio - (15mbps-1080p-L4.0-4ref-dualAC3.trp) - Had to rename to .ts - Strange flickering and green lines all over the screen
post #1466 of 6184
Issues such as compression artifacts and a 10mps stuttering video sound like bad rips to me. Do these videos play fine on other streamers?
post #1467 of 6184
Bozzeta,
How do you like NTV550 compared to Boxee?
post #1468 of 6184
I've not been able to test anything. I'm not at home yet. I need to rip some dvds with region coding intact to test if it only applies to external dvd/bd-drives.
I don't know what Netgears fw-plan is. But seperate fw is usually not a good thing for us European customers who usually import movies from the States.
Yes it says 5 times in the menu. Unless you get 5 more times with every re-flash you are out of luck.
But anyway, it's just a warning for those of you in the US who are importing the 550.
You need to check if you will be able to flash the US fw.
There is no problem flashing a different region firmware. I did it once just to see if my R5 BD rip of Avatar would play. For some reason, the region coding did not get removed when I ripped it.
Also, upgrading the firmware does not reset the region change count.
post #1469 of 6184
Bozzeta, Thanks for testing out. Some of the files in our test suite are from candre23's thread, and you have given some inputs for NTGR to look into. I will also contact NTGR NTV 550 PLM / dev about your results (particularly, the L4.1-8ref-6ch-FLAC-SSAsubs.mkv problem would make many anime users unhappy, and support for stylized subs would also be good)
No, those are not 'bad' rips, but they are not as per Blu-Ray standards, that is all. All the clips play fine in a HTPC and streamers such as WDTV Live Hub get, for example, that 1080i60 file processed correctly. Almost all streamers get stuck in one test stream or the other. It is just a matter of which one can come out as good as a HTPC in playback ability while retaining ease of use.
post #1470 of 6184
Really? I'll download these clips and try them out on my streamers.
Thank you
