Originally Posted by
skro
Hi Robkwil61,
As a followup to the great work Pete has done with MCM....have you been successfully using it for your files? Are there any tagging issues remaining?
I've downloaded it and tried it, but since I can't actually test the .tag files on a NTV550 (yet), I'd like make verify that it does work as it should before thanking him by purchasing a license.
I've been VERY pleased with Pete and MCM. The TAG files work great. There has been an issue about time/duration of the movies but I believe this to be a bug with the Neo and not MCM. Apparently Netgear's Tag Tool does not actually put in the TLEN field in the TAG but Pete is including the field. However I find that when a Tag file is present for an mkv file, the Neo reports 0 seconds duration for a movie. Remove the Tag file and the Neo properly reports the duration. I've reported this bug in the private beta forum.
I highly recommend anyone who has purchased the Neo, to download MCM and start getting their tags in order. And I would ask that you purchase the software and support Pete, rather than just downloading the free version. Beside you get a lot more functionality with the licensed version.
