Originally Posted by OnlyMe
Correct. Or, possibly, that the firmware has been optimised for USB streaming and not for network streaming.
If people stop and think about it. If the Neo needed gigabit in order to be able to stream high bitrate content properly don't you think netgear would have added a gigabit NIC? It would make no sense to "cripple" a streamer by taking shortcuts and only going with a 100 meg NIC.
You need to account for the bit rate of the content you're streaming. AFAIK, the highest bit rate of blu-ray movie is in the range 50-70 mbps. So for streaming movie, 100 mbps fast ethernet is more than enough for the player. On the other hand, your NAS server will require gigabit bandwidth if you want to stream to multiple players same time.
I only wish I knew WHAT kind of bandwidth I was getting with my Seagate, as I'm connected to the network through the RJ-45 in the back of my Uverse box, which is plugged into the wall via coax cable. It handles all the content I have without issues. (I don't presently have any BD rips or anything like that.)
