Netgear NeoTV 550 - Page 91
post #2701 of 6187
Originally Posted by robkwil61 View Post
Originally Posted by Sean_W_Smith View Post
play music to multiple zones
play different stuff to different zones
. . . You can do psuedo multi zone if you have a second Neo using the Follow Me feature, but it would be the same music.
Of course, if you have multiple Neos, there is nothing keeping you from playing different music in different zones.
Gear mentioned in this thread:
post #2702 of 6187
Originally Posted by shin0bi23 View Post
vorbis is not suported, also it was said on the netgear forums that some form of headercompression was not suported. i beleave it was "zlib"
maybe this can be the cause.
And his first audio track is DTS, so unless he has the Neo set to downmix DTS, he'd need a DTS capable receiver to hear the audio.
post #2703 of 6187
Good point.
post #2704 of 6187
Originally Posted by kncowans View Post
Can I ask, what tweaking is required?
I do not have a Harmony Remote yet but it is on the list.
Thanks in advance
Kevin
Get the Harmony One. You'll be glad you did. I just bought my third. $79 used on eBay and it works great.
post #2705 of 6187
Originally Posted by 720p View Post
I tried enabling nfs on my w7 ultimate x64 but didn't work. Not even sure it has that capability. smb/cifs is stutter free so left it at that. Anyone can confirm whether w7 ultimate x64 has native nfs server support and how to enable it and if it works with the neo? I know you can install 3rd party nfs servers.
I have Windows 7 Ultimate/64 and use a small program called HaneWin NFS and another one called Allegro NFS. Both of these work with Windows 7/64 and probably with most media players.
post #2706 of 6187
Does Netgear work on firmware updates for this player? Is there contact made with the Netgear guys or noone hears from them at all? They are a larger company, and usually the larger companies you don't hear from that much and firmware fixes come too far and inbetween?
post #2707 of 6187
If you just took 2 minutes to look at the Netgear forums you would have seen that since the release (1st of December for Europe) there have already been 2 releases, 1 stable and 1 beta firmware.
To me this shows that they are at least dedicated to resolve issues as quickly as possible. It also seems that they follow discussions on their forum.
post #2708 of 6187
Those are some good suggestions. You should open a feature request case up to Netgear. And post this in their forum to see you if you get support from other users who'd like these features.
On the fly playlist creation is already possible. You can do psuedo multi zone if you have a second Neo using the Follow Me feature, but it would be the same music. Additional visualizations has been requested but never implemented. Internet radio support got a big boost in the Neo in my opinion with the inclusion of RadioTime. Of course, anything related to hardware can't be changed so additional analog inputs would have to wait for the next model.
BTW: thats not my wishlist. you asked a question about what more music focused products are offering and that was a smattering of the more interesting ones.
So some more questions since mine hasn't come yet. So with on the fly play list creation. If I pick an artist and hit add to play list it will add music from that artist to a playlist or for example via genre?
I'm not sure what you mean by pseudo multizone. with the apple, logitech and sonos solutions I can easily play the same music synchronized to some number of zone all at the same time. What's the # of supported zones. Is it simultaneous to all zones and is it syncrhonized.
and does anyone know if this will playback Hi res FLAC files without dithering or re-sampling?
How bout standard stuff. Do CD rips come out at 44.1Khz and DAT rips at 48Khz or are they being re-sampled as is the case with most of the players on the market.
looks like my unit may have arrived at home but I'm on vacation for a bit so it will have to wait till I get back.
Sean
post #2709 of 6187
That I understand but how does one control it. The more music focused products offer a simple and unified way to manage a number of zones via their OSD or SmartPhone type interface. Sonos has this dialed in best. Logitech is a little weird and apples is simple but wont play some song in 2 zones and another song in 3 zones where as Logitech and Sonos can do this.
Sean
post #2710 of 6187
or the 900 if you are a RF Fan. Both are excellent choices.
Sean
post #2711 of 6187
"kick ass" bdmv structure says "checking for update" (weird) and then screen goes blank when i try to play. anyone got this bluray and can check it out?
post #2712 of 6187
Well... All my problem files still don't play and auto fps is not working. 1 month of no fixes in my book.
They way this player handles subs with mkv/avi is a deal breaker. Also don't get why some sub formats are displayed with fonts that have transparent shadows. It looks like **** against the background.
For US customers there will likely be little problems, but for the rest of the world this not good.
post #2713 of 6187
Having a few issues with the 550. For some reason, when I first play a movie, I notice the res is 1080i. I have it set to 1080p/24 in the menu. When I switch it to 1080/24, all of a sudden the video starts to stutter and drop the audio, like it doesn't have enough bandwidth. I have it wired direct to my router and playing from my pc shares. With the a-110 I had a problem, but it was myihome, once I just went to direct shares it was fine.
I have my folders shared over multiple drives attached to a pc running xp media center. Only 10/100 realtec nice in the pc, gigabit router cat 6 cable. Get between 50-80Mbs on the netgear test. I downloaded a nfs server program and have it running. How do I get nfs to work with the 550?? Tried to manually setup the share with nfs in the menu, but no luck. Pc name is mediapc and one folder is called moviesf, for example.
post #2714 of 6187
This sounds not like a bandwidth problem because the information will be streamed bit by bit and converted in the player whatever resolution you have selected. A player can not tell your server to send less information just because you have selected eg 720p.
It's either a deinterlacing or codec issue or autofps problem if you can play everything else.
post #2715 of 6187
It plays everything fine sometimes, but sometimes I notice it is playing 1080i and when I switch res to 1080p/24. The movie starts to slow down and stutter.
Auto fps is off. Doesn't work at all. You would think after the patch it would at least detect ONE blu ray iso or m2ts file as 1080p/24 no??
post #2716 of 6187
After +8 months you would think that they would have that fixed yes
I like that it playes progressive mp4, but the rest is mehh...
720p have you checked alising problems with your Knight and Day yet?
My panasonic bluray does not have problems with those scenes.
post #2717 of 6187
Just speculating here, but could the reason for no external bluray support be that Netgear would have to implement Cinavia because it's legally bounded to AACS license now?
Cinavia on a media streamer would not be good...
post #2718 of 6187
Found this older AVS thread on the Rec709 issue:
http://72.9.159.100/avs-vb/showthread.php?t=1208518
post #2719 of 6187
So can anyone give me some tips setting up the 550 with nfs in xp?? Using hanewin nfs server software.
NM got it to work, still stuttering gotta troubleshoot.
post #2720 of 6187
I upgraded to the new .275 firmware, but have found a few issues. Mainly I can't get my SD card to format. I've tried 2 different cards and it keeps saying that it can't read it. How can i revert to previous version?
BTW, it did fix the youtube issue, but I never use it. Everything else is great, but the system is overall less stable. I guess that is to be expected with a beta version.
post #2721 of 6187
Originally Posted by Ein View Post
Does this means Amazon will get their batch around the same time or earlier?
Yes they will. There is more product slated for January then there was for December. But quantities will still be limited but should be 2 to 3 X what it was in December. Bob Silver Netgear
post #2722 of 6187
You should be able to just do a regular update from the Neo and it will find the .268 version and update you. It may warn that the update version is previous to your current version. Just ignore and proceed.
post #2723 of 6187
I have been searching, so I apologize if I missed an answer somewhere. I have a lot of .Flac music files with some Windows Media Lossless files mixed in the same folder. It seems that the wma lossless files cause the Neo to crash. Does the Neo support wma lossless? I assumed it did. If so, maybe there is a tagging or other problem with the way I ripped the wma lossless files.
Thanks. Dean
post #2724 of 6187
Quick answer to my own question on previous post. The wma lossless files do indeed cause a crash. I deleted them and am reripping those files to .flac (which works great).
post #2725 of 6187
saw another claim that audio would not play if vorbis was present in the stream
here
post #2726 of 6187
Fist time I inserted a SD card i put it upside down. the card was listed in some of the menus so i asumed it was right , when turned around the spring mechanism could be felt clicking lightly in to place. then is showed up in more menu's
post #2727 of 6187
here
Exactly... audio track 2 will not play at all. Audio track 1 will require downmix or a DTS receiver.
post #2728 of 6187
The claim is that neither track will play not just the vorbis track
post #2729 of 6187
+1 .. I have 2. One in the Master Bedroom and one in the Garage. These are awesome little remotes. Tough to beat for the price and great for one handed surfing. I hardly use my Pronto 7500 in the bedroom anymore.
post #2730 of 6187
I only did a quick test and need to re-visit but:
1) I can't test 1080p yet (awaiting fix from netgear).
2) At 1080i I don't see any scaling artifacts although the image is nowhere near as good as 1080p23.976 from my htpc. (probably different processing from tv at 1080p23.976 vs. 1080i)
3) At 720p both netgear & htpc are terrible in the above scenes. The htpc is much worse than the netgear. (didn't expect such a difference to be honest).
4) My blu-ray player destroys them both in every test (no surprises here).
The image posted is a screen cap via remote desktop (I'm not at home) I posted for fun. I deliberately resized the tmt3 (my blu-ray player software) window to show the scaling artifacts. Now when testing the neo I can't remember if the bottom of the doors were that bad, I remember the vertical door shut lines breaking up though.
The cage scene is not subtle at all, extremely noticeable. The steel mesh is seen badly shimmering (think moire pattern in MI:3 stairs).
Can you test the cage scene on boxee @ 720p & let me know? At the end of the day playing blu-rays at 720p makes no sense to me so this doesn't bother me.
