Sorry if this has been covered. I couldn't find anything. Anyone know how to create a music playlist either with the remote or via the network Neo interface.
Regarding TV series, anybody know how to get Media Center Master to rename each episode and add a .tag file for each episode? Right now all I get is one .tag file in the folder and the episodes don't rename. I was hoping to see this functionality:
Current config: SeriesName\\Season\\ep1, ep2, ep3, etc. I want MCM to rename each episode as "EPISODE# - EPISODE NAME" and add a tag file for each. That way instead of "Happy.Days.s01e03.mkv" it would show "3 - The Fonz kills Richie" when I browse the files. |
General Format : Matroska File size : 9.03 GiB Duration : 2h 6mn Overall bit rate : 10.2 Mbps Encoded date : UTC 2011-01-01 00:15:08 Writing library : WonderShare Matroska Muxer Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Baseline@L3.0 Format settings, CABAC : No Format settings, ReFrames : 1 frame Codec ID : X264 Codec ID/Info : XiWave GNU GPL x264 MPEG-4 Duration : 2h 6mn Bit rate : 9 817 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 30.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.355 Stream size : 8.68 GiB (96%)
Trying to get everything else ready. Hardwired network - Linksys E3000 router, Synology DS410 NAS. Router is in a different area from media equipment and would like to add a switch at the media center. I have read some posts of problems with some switches not working correctly as far as internet services. Anyone have recommendations for a 4 or 5 port gig switch?
