Originally Posted by robkwil61
Well glad it is not a major issue for you but I'm still intrigued as to why it is not working. Have you tried using the server IP and the share of "shares"? For kicks, set up a folder named D:\\Test. Then on that folder, create a share called Test with no security. Place one media file in it. Then add the NFS share to the Neo using IP address and Test as share name. Your multi level folders under the main share might be the issue.
First, thanks for the advice.
Second, the issue is now moot. After flashing 3.0.308 the video stutter with high bitrate .iso has been fixed.
Tests with Startrek (2009) and the
Thomas Crown affair > 40 Mbs show no stutter anymore.
Stutter is back, See edit
The NG developers are to be congratulated.
However the problem with Video freezing on .mkv with DB THD and subtitles enabled still has problems. It now works with avatar.mkv but still freezes with Blade Runner.mkv and 2001.mkv.
BTW the multilevel folders under share are the WHS default and since the Dune H1 reads these with NFS the Neo should as well.
Regardless, I will conduct the test you suggested and post in due time.
The Thomas Crown Affair stutters bad, unwatchable.
