I'm trying to find a sub (or build one myself) that would sound good for home theater and music. My benchmark is the JL F110, but I don't want to drop $2K on a sub. Also, no other sub that I've come across that's reasonably sized, has a more-capable woofer than the 10W7 with its 3 or so inches of excursion.
One thought would be to just use a JL Prowedge with a 10w7 and power it with a large enough amp that could handle the 3 ohm load. These can be had for $500 new.
http://mobile.jlaudio.com/products_e...=5&prod_id=302
I am, however, concerned that it won't be able to extend as low as the F110, but will it come close in room? The F3 of the optimal sealed 10w7 enclosure is 40.7 hz. That seems kind of high. The net air volume of this Prowedge is right around 1.25 cubic feet after subtracting for the woofer's displacement.
The room is about 14x15x13.
) I just want good extension and sound quality.
