EDIT: This is for PA, not home audio or HT.
Ok. I've never built a bass horn yet and after experiencing Labsubs and lately the DTS-10's I've gotten the itch to give it a go. The ported 21's are about a week away from being wrapped up and I've finally decided on a horn simulation that I'd like to turn into a pile of sawdust and wood...I think.
I figure I'd better get the ball rolling if I expect to get this built before weather turns bad for the winter.
I've run through a ton of simulations in the last 6 months and there are about 20 possible scenarios that I like and about 8 that it was really tough choosing between for the build. I weeded that down to about 3 possibles by eliminating the ones involving drivers I don't already own. Why buy if you don't need to? I ended up deciding on a 380L net, 30hz FLH using the LMS 5400, over a 380L 30hz B&C FLH and a 30hz 380L B&C TH.
The performance of each is close enough on paper to make it a toss up really.
For the curious here's my thought process. The other contenders were involving dual xxx12's in a TH, TC's PA5100 and the 18sound 21NLW9600. The 18sound 21 and the B&C are VERY similar in performance when using the same enclosure, basically interchangeable IMO with very small differences in modeled performance, so that eliminated the 18sound because I already own the B&C. The PA 5100 also models very well, but differently in the same basic horn parameters as the 21's but obviously needs some changes in the overall form factor due to being a smaller diameter deeper driver. Again since none of them really showed a notable performance advantage on paper and I already own the B&C's...The dual xxx 12 sub I would really like to build (sub bass gargantua), but it's the most complicated, expensive, heaviest and largest. Maybe later. The LMS I decided on over the B&C, because it's the less obvious choice and more of a known quantity at this point. Plus I'm already doing a new build for the B&C's. The build I am doing will be leaving some of the LMS's potential on the table. It'd be better in a larger 20hz FLH or an 18hz TH, but I don't want to build anything so large and difficult to move first off. If I can't easily fit it in the back of my Jeep with the help of 1 other guy it was eliminated this is also why I ended up with a 30hz corner. The LMS doesn't like TH's so small tuned so high.
Anyway. This is what I've got. Nothing is set in stone yet. I need help reviewing the model for mistakes and I could especially use some help with folding the horn up. I've never folded one, so help or comments from more experienced guys would be much appreciated. All opinions are welcome.
BTW the model is intentionally a very basic single expansion rate conical (parabolic now) type to hopefully keep the folding and build as simple and straight forward as possible.
Input parameters
Attachment 183905
Phase and delay
Attachment 183906
1W into the minumum impedance in half space
Attachment 183907
124v input in half space
Attachment 183908
124v driver excursion
Attachment 183909
I figure I'd better get the ball rolling if I expect to get this built before weather turns bad for the winter.I've run through a ton of simulations in the last 6 months and there are about 20 possible scenarios that I like and about 8 that it was really tough choosing between for the build. I weeded that down to about 3 possibles by eliminating the ones involving drivers I don't already own. Why buy if you don't need to? I ended up deciding on a 380L net, 30hz FLH using the LMS 5400, over a 380L 30hz B&C FLH and a 30hz 380L B&C TH.
BTW the model is intentionally a very basic single expansion rate conical (parabolic now) type to hopefully keep the folding and build as simple and straight forward as possible.Input parameters
Attachment 183905
Phase and delay
Attachment 183906
Attachment 183907
Attachment 183908
Attachment 183909
Really though, it makes a difference in some models. More so in standard single flare horns.
Yeah getting crazy high SPL at 100Hz is pointless, you'll just end up with a boombox, just bigger. A lot of people tend to forget the human hearing curve, and that a measured flat response does not = audible flat response, especially down low.
