Aww, BFM caught me ghosting there.
I'm not sure how you judged the sensitivity, but Ilkka doesn't measure it.
"Frequency response was measured crossover at its max and min settings and also bypassed if available. 10 second sine sweep from 200 Hz to 10 Hz was used. Level was matched at 90 dB at 50 Hz at 2 m distance."
He also used 2m distances for everything, so the conversion to standard 1m apply.
I do agree that it wasn't the best horn, but at least it looks like they used the mobile audio version of the XLS, IIRC.
