Somehow I missed these questions a month ago...I just saw them when I came to update the CEA2010 data.
I guess it should certainly be loud enough if you use 2-4, for most applications, but really the cab loading is lower than needed, and it is really big and heavy. You could gain a lot of top end output and efficiency in the meat of the live sound range if you moved the corner up a whole octave higher. You know like the Othorn. Basically the Gjallerhorn would be OK 40-90hz, but some smaller, lighter cabs can compare favorably over that range. It isn't until the octave and a half below that range that it starts to set itself apart from the normal live sound gear. In most live or SR instances that sort of content is pretty much non existent anyway though. Everybody usually filters below 30hz pretty heavily to protect their equipment and cabs and live music doesn't have much below 30hz anyway, so the extra extension is wasted in that application.
Don't get me wrong I am using them for live sound right now
but they are stationary, it is only for myself and I run the system.
Violently. The pair that I have have been pushed in the >10,000cu ft very lossy space they are in a few times, just having fun with them and it is more than plenty for that space. They can shake the entire building and easily pressurize the space with Jurassic Lunch and I only have about 1300w of amplifier going to each one. They aren't even using all of that power. Some people say there is no such thing as overkill, but seriously the Gjallerhorn is simply not needed in any sort of domestic environment. Even one will do reference levels to 16hz in a normal room without breaking a sweat. I guess if you had a screen wall it might make some sense, but most of the time I doubt that you would use much of the available headroom. Most situations would be better served with multiple smaller, more modest subs scattered about the room to smooth the response.
I'd be lieing if I said that I wouldn't like to experience what they would do "opened up" in someone's HT room just once though. Maybe someone will have a GTG I can drag one to.
but they are stationary, it is only for myself and I run the system.Quote:
Atleast it is a response improvement.
