AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › New Sony NX710 and NX810 models
New Sony NX710 and NX810 models - Page 11
post #301 of 480
Originally Posted by sbx007 View Post
What do you mean?. My 60nx810 plays perfect from all angles. I'm lookiing to critisize it. I can't nor can anyone else. Maybe its the signal or service provider?. The image on non-hd channels(for my case) is spectacular. I'm watching hockey games, Baseball, news broadcasts with the graphics..non-hd. I can't find fault.
Thats exactly what I mean. Its like other LED TV you lose some contrast. But the picture is still very good and very watchable so whomever criticizes the set for poor off angle viewing must be a very particular viewer. I find the NX810 overall a solid set
post #302 of 480
I purchased the magnificent 55NX810 last Saturday. I have no complaints about the picture quality. It's fantastic in both 2D and 3D.
But I see an annoying problem:
I CAN NOT ACCESS THE PIP (picture in picture) FUNCTION.
According to the i-Manual, to access PIP, you go to Options then to PIP while watching air or cable TV. Surprisingly, the PIP setting does not appear anywhere in Options! I couldn't find it in the HOME menu either. I tried finding it in Options with different inputs on the screen: HDMI, Component, TV, and PC (with an HDMI connection). Still no success. It's almost as if this TV does not have PIP. Do any of you owners have PIP on this set?
post #303 of 480
Does the KDL60NX810 do 1080P/24 signals at multiplies of the original frame rate. If so do i have to turn off Motionflow and CineMotion to achive this or do i have to leave Cinemotion on. I am pretty sure Motionflow has to be turned off but what aboot Cinemotion? Thanks. Super bright tv love it coming from a wd73-833 it is night and day DLP is dead.
post #304 of 480
Originally Posted by dkam View Post
I haven't tried running a 3D movie through my system yet. I should check it out to see what happens. Other than that the 5400es is an amazing receiver. The new 5600es is full 1.4 compliant and has some other great features. Been very happy witht he Es receivers over the years just like my older XBRs. No problems whatsover
Some kind sole left this for me.. It's worth the read. I think 1.4 ethernet is the way to go from this link.
http://hdguru.com/3d-hdtv-and-hdmi-explained/1336/
post #305 of 480
Originally Posted by gripen08 View Post
Well how about that. I also got a 25" XBR waaay back then. Got mine in black. I do remember the mauve ones, and I think there was another color available as well, maybe light blue or white. I remember Crazy Eddies well but I got mine at a small place called Prisco's in Westchester Co. BTW, it is still going . Now down at my mother-in-law's. Had to replace a part for about $100 around 6 years ago, but it was worth it. Still a great bedroom TV as is the 32" XBR100 I got back in '95, the one with the separate "feature box". I had a 27" non-XBR that my mother-in-law also now has. AND still have 2 13" white little monsters that won't die either....amazing. (My original Sony was a 21" model with the wood paneled sides and rudimentary remote, meaning up and down channel selector, no numbers to punch in).
Anyway, to the subject at hand, the NX810. I'm going to demo one when it comes in later this week vs. the HX909, and the LX900 (at another store). Looking for 60" minimum (wish the 909 was bigger than 52"). I have checked out the Panasonic VT25, Samsung plasmas and LCDs and the Sony NX700, NX800 and EX700. Best overall PQ so far was the Panasonic but it is a little dark and aesthetically can't hold a candle to the monolithic Sonys. I'm primarily interested in PQ in regular 2D (not into 3D yet), and what it looks like with HD and SD. I'm also into movies and want to see if shutting down enough picture enhancement will avoid the soap opera effect. Don't care about audio capability as I have a B&K 5.1 surround system , Vienna Acoustics fronts, rears and center, and a REL sub. Will let you know my impressions later this week on the Sonys.
Cheers...........
Yes. There was one other color. The mauve wasn't that bad at all. Chicks loved it .. I remeber the 21 incher w/ the wood panel, I think my parents had one. I think you'll like the 810. I looked at a lot of TV's. They all for the most part are fine. However 60 inches of nx810, I got no regrets. When I gave an 82 yr old sceptic those 3-d glasses and couldn't get them back..No regrets. BTW - I bought my first real "stereo"
@ Prisco's, lived in Yonkers back then. It was a panasonic jobby with an 8-track that popped up, I was 13 .. along time ago. When the 32" came out, and my friend got it I was really jealouse. Those CRT's looked pretty good back then.. it's all relative
post #306 of 480
Yah..We're all different. I'm w/ you no complaints..yet..Hockey is incredible on this beast!.
post #307 of 480
Not an owner, but most sets will only display a picture in the PIP window from the integrated internal over-the-air (antenna) / cable tuner (ATSC/QAM). You can watch HDMI, component, PC, and TV input in the Main window, and only antenna/cable (TV) input in the PIP window.
This means you have to connect an antenna or cable to the coaxial RF (TV) 75 ohm connector on the back of the set. Then scan for over the air or cable channels using the autoprogram feature. Your set may not even display the PIP option if these two conditions aren't present.
If you are using a cable box, you can use a splitter and split the cable before it goes into the back of the box, and feed the second lead into the RF connector on the back of the set. In flat terrain, a $37 RCA ANT1250 indoor amplified antenna can pick up stations ~ 25 miles away. (PS: this setup also allows us to watch a TV show while our dual HDDVR is tied up recording 2 programs.)
If you're set up this way, and it still doesn't work, let me know and I'll try to download the manual for your set and see if I can see some other problem. I'm stuck in a hotel and have the time. Good luck.
post #308 of 480
All the NX810 models are supposed to have PIP, according to the official Sony specs. The owners manual is integrated into the TV (very handy!), but it is not available online for download (not very handy). It clearly states that PIP comes with these sets.
I do have antenna air TV hooked up, and have scanned for available channels, but still no PIP function is available.
Thank you for your offer to help, but I really need for an actual owner to investigate this problem.
post #309 of 480
PIP only works when you have PC (computer) input and another input per the i-manual. In fact, PIP does not even show up in options unless two inputs are present. Below is the quote from the i-manaul (online http://esupport.sony.com/docs/imanua.../1a/index.html and confirmed on my 55NX810
“PIP” displays a picture from the connected PC in the full screen, and a TV program or composite video in an inset window. This feature is available when a PC is connected with an HDMI cable. Available inputs may vary depending on the TV model.
Now my 3 year old XBR4 was different as PIP allowed you to watch a TV channel is window and any other input in another windown, both displayed at the same time
post #310 of 480
Does this TV support reverse audio channel HDMI and Ethernet over HDMI?
post #311 of 480
Ain't that the truth... Thanks for the input on the 810. We shall see when I check it out this week.
post #312 of 480
PIP displays a picture from the connected PC in the full screen, and a TV program or composite video in an inset window. This feature is available when a PC is connected with an HDMI cable. Available inputs may vary depending on the TV model.
Guys, there may be some wiggle room in the quote.
1. It says the main window needs a PC connected via HDMI. But then it says "Available inputs may vary depending on the TV model."
2. It says a "TV program or composite video in an inset (PIP) window." To me, a "TV program" comes in via the internal tuner from an RF 75 ohm input.
So, connect the antenna/cable to the RF input and scan for channels to let the set know the PIP input is available. Then, while watching from the cable/satellite set-top box connected via HDMI, try selecting PIP from the Option menu.
My Samsung, your XBR4, and most one-tuner TVs allow HDMI, PC, Component, etc. inputs in the main window and internal tuner (via 75 ohm input) in the PIP window. e.g., the external tuner in the set top box, PC, etc. provides one feed via HDMI, and the internal ATSC/QAM tuner the other via RF.
Give it a try. Nothing to lose. Good luck.
post #313 of 480
HDMI #1 is also an ARC port. I have an externasl audio connected via HDMI #1 which also has the BluRay. For info, TV has 4 HDMI ports, twq of the ports are on the back and two on the side. Only one of them is ARC and it is on the back
post #314 of 480
NO WIGGLE!!!! When I am using HDMI#4 (my FIOS box), and select 'options' there is no PIP selection on my 55NX810
post #315 of 480
NO WIGGLE!!!! When I am using HDMI#4 (my FIOS box), and select 'options' there is no PIP selection on my 55NX810.
I have cable input split-with cable in to both the TV and the DVR-that way I can watch a local channel if I am recording two channels on the DVR. I periodically watch TV straight into TV bypassing the cable (FIOS) box, as sometimes the surround sound is better since the FIOS box compresses the audio stream
post #316 of 480
I think older xbr used to have two tuners built in one hd and other possibly non hd or hd not sure so u could see two channels in pip but cost cutting might have done the damage leaving single tuner
post #317 of 480
BTW, I found an old marketing pamphlet for the 25" XBR and the mauve was actually called Plum and the other color was Beige which almost looks like a light yellow. And there was a pedestal stand with foot controls and you could attach the speaker to the sides of the stand instead of the TV. There was also a 20" version too. Pamphlet is dated 11/84. Also had a bunch of other accessories like a clock timer remote control, other stand/cabinet options and believe it or not a wireless headphone setup called Remote Control Stereo Receiver/Commander !! Brochure starts with statement "You may have bought your last color television" "That's not a threat. It's a promise". And "At the top of theTrinitron XBR line stands our outstanding KV-25XBR: a giant-screen model with audio and video entertainment possibilities......" I like the term "giant-screen" , shows the perspective back then.
Ok enough...didn't want to turn this into the Sony KV-25XBR owners thread but interesting nostalgia nonetheless...
post #318 of 480
Yup! Plum!. I still have that stand..Threw the TV away but kept the stand! It was the last stand Crazy had, they were hard to get. It had a huge sign with In UPPER CASE - DO NOT SELL RESERVED FOR ... but the sales guy ripped the sign off and gave it to me. Then I started getting phone calls. The guy wanted his stand. I ignored the calls, and so did my parents
post #319 of 480
My 51" Sony CRT RP TV has P&P named TwinView with one HD tuner on the left and a 4x3 analog tuner on the right. My Sony W3000 sets that I sold to a friend had P&P (similar to TwinView), plus PIP that utilized the VGA PC input or HDMI w/PC timing and a small moveable window for TV from the RF input.
post #320 of 480
Thanks for your comments Donald, and for finding an online version of the i-Manual.
I have tried connections of almost every type. (Component, Air TV, Cable TV and PC w/ HDMI. (I did not try VGA with PC or Composite however). I also auto-programed the air TV and Cable channels. I turned the TV off then on. Nothing works. PIP still does not appear in the Options list. I now think that PIP is not available on this set as advertised by Sony. I hope at least one of you actual owners can prove me wrong. Does PIP work for any of you NX810 owners?
post #321 of 480
I went to the website and typed pip in the faq box and it did say something about the PC sending a timing signal to the TV. That must be required to make it work in the main window. I also split my cable to allow us to watch live TV while our Comcast HDDVR is recording two channels.
It looks like Sony has taken 2 steps back on PIP with this model. However, while I am glad PIP allows us to watch the cablebox in the main window and live TV in the PIP window on our Samsung, you guys aren't missing much. It's menu driven which makes changing channels, window size, and sound source difficult. I basically monitor one channel in my PIP window and switch the main window to that channel when something interesting happens, then hit the Last Channel button to go back.
My old Sony 36XBR450 CRT with 2 tuners had P&P (twin view) controls on the remote which made it easy to change channels, size of window, and sound source. It was great and I'm still looking for that user friendliness. I don't understand why these one tuner models can't provide it... the set top box provides the second tuner. That's why I jumped in here to learn about PIP on this model.
post #322 of 480
John, re-read Donald's note. He is an owner and has split his cable and tried to feed a set top box signal via HDMI to the main window, but it just doesn't work. Like John mentioned, recent Sony models did allow you to watch 2 programs in the manner we've been discussing, but this model seems to require one of the inputs be a PC.
You mentioned trying a PC with HDMI. That is exactly what the manual says will work. Did you have that playing on the set when you went to Options to enable PIP? If not, then PIP seems to be mis-advertised for this set. Nonetheless, even if it does work, it won't allow you to watch 2 programs at once.
If you really want to watch 2 programs, then possibly you could return your set for one that does. Read my reply to Donald above for a description of Samsung's PIP. Or, hopefully, some other owner lets us all know how to do that. I'm interested in this model because it seems like one of Sony's best values at this time. However, its PIP seems to have taken 2 steps backward.
post #323 of 480
810 does have ARC Yes, it's the TOP HDMI port and clearly marked, you won't miss it.
Ethernet no. If it did then the modem/router would have to support HDMI I would think..Plus it's got wireless, but ehternet/hdmi when ready would be nice. Don't know of any TV's that have it. The 810 does have a direct ethernet port. Those HDMI 1.4 cables w/ ethernet., I think they're meant for the componants maybe.. that's my understanding of it. there's a good link somewhere, if you google hdmi ethernet there's an overwhelming amt of info. I never wanted to know this much about HDMI. I wish I could forget it
But I would like to know in what cases HDMI/Ethernet is in use.
post #324 of 480
Thanks guys. I was kind of hoping the Wireless in the 810 would be able to route the internet connection to my VSX-1120 receiver so I wouldnt need to route an Ethernet cable to that as well.
post #325 of 480
Zoglog,
Where did you get your great deal on your 55NX810 (I saw it in the other thread). Thanks, Mike.
post #326 of 480
Originally Posted by Viper2847 View Post
While it may have a nicer design, that opticontrast panel makes the picture look darker/duller.
Therefore, as far as performance goes i would still rate the HX800 above the NX810 as the standard glossy panel does not reduce the overall brightness like the glass seems to do. Im pretty sure the NX810/HX800 also both use SPVA panels, and not the superior Sharp UV2A panels found in the HX909/LX900.
And the HX909>over everything else.
Precisely said, I looked at both today, same material, and went for 52 inch hx909 instead. I thought 3 inch smaller set for bedroom for almost 50% of msrp is no brained btw always owned a xbr here.
post #327 of 480
it's 52 inches and doesn't have the capabilities teh 810 has. Different strokes different folks. I saw the 52 incher hx 909. I wouldn't pay 2300 for it. Didn't compare to the 60 or the 55 inch 810 IMHO.
post #328 of 480
Doesnt have the capabilities tech the 810 has? Buddy, its the other way arround. The HX909 is full-array LED with local dimming compared to the NX810 which is only edge-led with local dimming-no comparison, at all.
Seeing these things in the store with the bright lights they have does not justify giving them a fair comparison, at all.
post #329 of 480
60 inches..909's aren't 60 inches. Compare a movie or hockey game, adjust the settings. I took the 60 inch 810. You like the 909. Good. Regardless of specs, I liked the 810. So comparing a 52 inch tv to a 55 inch or 60 inch is not a good comparison.
My 19" vizio plays beter than both
post #330 of 480
So a 55" or 60" Vizio edge-lit led is also better than a full local dimming set from Sony such as the HX909 just because its bigger?
Lets also not forget your comment said two things. "its 52 inches AND doesnt have the capabilities teh 810 has" yet the NX810 is the one equipped with far inferior hardware with everything from the type of LCD panel it uses and the backlight being incapable of even getting close to what the HX909 can reproduce.
I understand that size is more important for YOU than picture quality but thats not true for EVERYBODY and to say it doesnt have the same capabilities is absolute BS. Oh yeah, except it doesnt have built-in wifi, sorry i left that out.
