Thanks a ton for that HTF link to Van Ling's thread, Stefan. Great to hear it from the source re what happened with
T2's (mis)labeling.
Originally Posted by
AVfile
Firmware updated, now Neo:6 can be truly switched OFF. However I think they introduced a new problem in that Neo doesn't work with the DTS-HDMA 5.1 track at all now, no matter what the setting. So with Neo:6 set to "Cinema" I get 7.1 in the menus and 5.1 during the film! I'm just going to leave it off.
Chs4000 beat me to it: without even yet having gone to his link, I was going to reiterate what the 770 manual says, which is that it applies Neo:6 processing to 2-channel tracks to create multichannel.
AVfile
Also the player no longer indicates "DTS-HD Master Audio ES 6.1 Matrix 3/3.1 48 kHz" like the s550 did when playing
T2: Skynet. All I get is "DTS-HD Master Audio 5.1 48 kHz" and the ES flag is not passed to the receiver (like before) unless there is a bug in the Anthem which ignores the flag.
Thanks for quoting exactly what your receiver indicates is the audio codec and rez it is receiving with
T2. I was confused insofar as I didn't think there was such a thing as ES encoding with the high rez codecs. I've looked at many DTS style guides and have a few of their demo discs and none refer to that. Largely due to SA-CD and DVD-A, I've been analog m.c. for years so I am used to not getting explicit confirmation from pretty pre/pro/AVR lighting re exactly what codec I'm getting.
AVfile
Note: I popped in
Total Recall and got "DTS-HD High Resolution ES 6.1" which works as expected. It does
both bitstream 6.1 and 7.1 PCM correctly, so I kinda doubt there is a bug in the Anthem. More like
T2: Skynet is just plain confusing and the new Sony firmware has tried to eliminate confusion by ignoring the ES flag :|
Yes,
T2 audio track matters can be confusing. It's for that reason that I'd advise caution coming to any conclusions based upon how
Total Recall behaves. I note that
Recall is DTS-HD High Resolution versus
T2's DTS-HD Master Audio. I get your point but it's not a apples-to-apples comparison. Again, I'd spin a few Pixar BDs.
Finally, in a cheap gesture to getting back to topic, I don't think it's the case that Sony decks are ignoring ES flags. When I spin the
T2 BD on the 470 (M04.R.708 fw) and select the DTS-HD MA track, my Denon 3803 sees the ES encoding, shows "ES MTRX" on its display and gives me surround back channel playback. I'm unfortunately using SPDIF since the 2010 Sonys don't have m.c. analog outs and the 3803 is non-HDMI (the Denon DBP-2011 is on my purchase horizon).
I suppose it's possible that changing only the connectivity to HDMI would produce a different result. But highly unlikely.
