Originally Posted by pinzg35
thanks. i have tried csamos and like it but will try yours tonight. can i ask why it matter is you have one hdmi going to the tv from a receiver with things plugged into that compared to each device going into the tv separately? in the end, isn't the screen producing the PQ and not the device? just confused why you need an individual setting in your case.
thanks!
thanks!
In my case, I have all of my devices in both my living room (blu-ray player and DirecTV receiver) and theater (blu-ray player, DirecTV receiver, 2 DVD changers) plugged into an a/v receiver via HDMI so that the a/v receiver can process the uncompressed and 7.1 channel HD audio formats (at least in the blu-ray player's case). If you connect a blu-ray player directly to the TV via HDMI but then only use optical or coaxial digital cable to get the audio to a receiver, you will not be able to take advantage of any uncompressed or 7.1 channel HD audio formats.
I had less off angle fade, I believe, on my hyundai, which is just plain weird. I might take that loupe to my old TV just for grins
